Anyone near Hummelstown, Pennsylvania?
  • FestYboy
    FestYboy Posts: 3,861
    I can be there in less than an hour, but have nothing to drive them properly or the $$. John, are you looking to make something happen?
  • DaveHo
    DaveHo Posts: 3,583
    Yes, but Lucy says "Those would make for a nice scratching post!". I don't have a large enough room anyway.
    F1nut Posts: 51,959
    DaveHo wrote: »
    Lucy looks like trouble.....lol
    nooshinjohn Posts: 25,986
    DSkip wrote: »
    It’s only a deal if you can use them properly, just like the seller states. Maggie’s are great speakers but truly require you to build a room around them which many can’t do.
    If you can accommodate them they can reward you for sure.
    That is not entirely true Skip. I have owned several Maggie’s, including the MG20’s, and found them to be very easy to live with. The trouble comes from them not being the best way to find marital harmony.
    The 3.6’s would like to see 2 to three feet off the back wall and a similar distance from the side walls. Believe is or not, they can be placed a few feet from and facing each other and deliver spectacular results in even a very small space. All they require is the dedication and equipment to get the best from them.
  • verb
    verb Posts: 10,176
    FestYboy wrote: »
    Fetivus to the rescue! Arty you are a jewel among us in this forum! :smile:
