Anyone near Hummelstown, Pennsylvania?
nooshinjohn
in Speakers
FANTASTIC, SMOKIN" HOT DEAL HERE!!!
https://www.ebay.com/itm/Magnepan-Magneplanar-MG3-6-R-3-way-Speakers-Stereo-pair-Ribbon-Tweeters/113992935237?hash=item1a8a822745:g:tngAAOSwvzFd4IzC
I can be there in less than an hour, but have nothing to drive them properly or the $$. John, are you looking to make something happen?
Yes, but Lucy says "Those would make for a nice scratching post!". I don't have a large enough room anyway.
Lucy looks like trouble.....lolPolitical Correctness'.........defined
President of Club Polk -
That is not entirely true Skip. I have owned several Maggie’s, including the MG20’s, and found them to be very easy to live with. The trouble comes from them not being the best way to find marital harmony.It’s only a deal if you can use them properly, just like the seller states. Maggie’s are great speakers but truly require you to build a room around them which many can’t do.
If you can accommodate them they can reward you for sure.
The 3.6’s would like to see 2 to three feet off the back wall and a similar distance from the side walls. Believe is or not, they can be placed a few feet from and facing each other and deliver spectacular results in even a very small space. All they require is the dedication and equipment to get the best from them.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Fetivus to the rescue! Arty you are a jewel among us in this forum!
