Cary SLP-05
    nooshinjohn Posts: 26,178
    edited November 2019
    Nightfall wrote: »
    Joey is like the 1989 Hyundai Elantra with a $25,000 sound system driving around.
    Fixed.
  • Joey_V
    Joey_V Posts: 8,606
    Haha
    You guys are funny
    I mean... a Cary 05 should not be $7800.
    I think around $5500 is what it should cost given the used market. That’s with the ultimate upgrade.
    But good luck finding one Joey. Those that have one will rarely part with it. Personally, I think they are not as good as the Pass Labs XP22 you can get for that price, or the XP30 that is getting close to that as well.
  • GlennDog
    GlennDog Posts: 3,158
    Joey_V wrote: »
    $7800 for a cary preamp is a little steep
    Yeah. If I was drop’n that kinda coin, I’d be looking at the likes of this ...
    https://www.audiogon.com/listings/lis9ie2j-vac-signature-mk-iia-preamp-tubes?utm_campaign=Saturday_Email_20191123&utm_content=saturday_email_20191123&utm_medium=email&utm_source=zaius
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • verb
    verb Posts: 10,176
    The VAC room at AXPONA was off the charts! Love to get some VAC pieces someday! :smile:
    audioluvr Posts: 6,079
    pitdogg2 Posts: 27,914
    audioluvr wrote: »
    They wouldn't need those tube dampers IF they ran decent tubes.
  • dromunds
    dromunds Posts: 10,176
    Don't understand it, like a veil on your sound. Plus, he has tube dampers on every tube.
  • jdjohn
    jdjohn Posts: 3,455
    That one is now gone. I had been keeping an eye on it. Whew!
    Not to sound stupid about tubes (because I am) but what's the function of a tube damper? I thought those things were so he could pull the tubes easier...
    Ah. Thank Skip. So the unique resonance of the tube itself is what gives them that live sound. Slowly catching on.
  • jdjohn
    jdjohn Posts: 3,455
    My understanding is that the rings prevent microphonics, but I'm a tube newb. Seems like unless you're having a problem with microphonics, the rings aren't needed. They shouldn't be considered a necessity, or must-have.
  • GlennDog
    edited December 2019
    DSkip wrote: »
    Not quite. It’s that the absorption aspect deadens everything. Absorption has positive qualities but also negative ones that, as you move up in the audio world, can really become major detriments.
    I have an inkling your resume does not include “English“ teacher. Perhaps applied physics with a concentration in noise, vibration and harshness?
    Pre Cary SLP-05
    Mains Salk HT2-TL
    Rythmik F12
    jdjohn wrote: »
    YES ^^^ If you have a microphonic tube get a NEW one that isn't
  • jdjohn
    jdjohn Posts: 3,455
    Would NOS suffice? :D
