Polk S30 or S35, which one should I get for my 5.1 setup
I just purchase 4 S15 for a 5.1 setup, and now i'm looking into getting the center Speaker, I was going to go with the S35, but now I'm told the S30 would be a better choice.
Can someone with the experience suggest which one should I buy because is better?
Thanks,
Thanks,
I don't have experience with the Signature series, but the S35 center looks like a low-profile sound-bar replacement and the S30 looks like a traditional center. I'd probably go with an S30 unless you need the low profile to fit under your TV or something.KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Yeah, that's what I'm hearing too. I have problems with the space, but I going to see if I can figure something out. Thanks,
I had a S30 when I had my S55's. The only reason I would go with a S35 is if you didn't have room for the S30. Just about every review I read said get the S30. Just look at the specs and compare the speaker sizes.Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables. SnubWay, Main Stream
^^^Agree^^^
If you have the room get an S30.When I was a kid my parents told me to turn it down. Now I'm an adult and my kids tell me to turn it down.
Working Warehouse; Yamaha A-S301, Sony DVP-NS3100ES for disc Plok TSX550T SVS PB2000 Mini tower PC with 400GB of music -
I have both the S30 and S35, they sound pretty similar - S30 is slightly more rich (i.e. sounds fuller) but it's not all that much noticable. S35 is a very good center.
S35 is a problem-solver type center speaker. But if you don't have a problem with space, stick with the S30.
