Rebuilding Amps
Lostsoul123
What are some good sources for audio quality capacitors? I'm considering at least replacing my power caps in my mono amps. They each have 4 15,500 @75v Phillips screw tops.
Any help would be appreciated.
All tube designed Hello Kitty boom box
Invisible aluminum wireless Phazer speaker wire
Free Spirit Teleport Preamp (Literally brings the artists into your living room)
1.44 JW Flux Capacitor Mono Amps
You can use higher or lower value capacitors, so long as you do not alter the voltage. EBay can be a good source, as well as Mouser.
https://www.ebay.com/itm/1x-30000uF-75V-Large-Can-Electrolytic-Capacitor-DC-105C-30000mfd-75VDC-30-000/132892290415?hash=item1ef0ff6d6f:g:F14AAOSw3ydVixHAThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Thanks John. I did look on eBay but didn't find what I needed plus not sure I want to trust something vintage that someone found on a shelf. Do electrolytics have a shelf life?Post edited by Lostsoul123 onAll tube designed Hello Kitty boom box
1.44 JW Flux Capacitor Mono Amps -
Lostsoul123 wrote: »Do electrolytics have a shelf life?
YES
That being said I've seen that brand use in many things. Best to just ask questions and go from there. Size is also a huge consideration as well.
@rebelsoul the OP needs 75v caps, not 100v caps. The uf rating can be higher or lower but the voltage has to be the same."Some people find it easier to be conceited rather than correct."
"Unwad those panties and have a good time man. We're all here to help each other, no matter how it might appear." DSkip -
Why? Why can you not go up in voltage? Many if us go up in voltage for electrolytic caps. Heck my Adcom preamp calls for 25 volt yet adcom themselves chose 35v for better ESR reasons in the end.
Not disputing Ryan I'm here to learn. Yes lower would certainly be a problem boom. -
Not disputing Ryan I'm here to learn. Yes lower voltage could certainly be a problem boom.
fixed
You most certainly can go up in voltage, but never down. For main filter caps in the power supply, you can also go up in capacitance, but never down.
Also pay attention to temperature rating and ESR...
I would also strongly suggest you avoid eBay for large filter caps - Chinese counterfeits are abundant. Further, a “new” capacitor selling on eBay May have been sitting on the shelf for 15 years. Buy from reputable sources like Mouser, Digikey, B&D Enterprises, Online Components, etc...Too much gear, too little time.... -
Thank you! So if I sent my amps to you for a refurb...All tube designed Hello Kitty boom box
I concur one can go up in voltage and capacitance.
I've had good luck finding what I needed at Tedss but not all of the time. I've used the reputable electronics places above as well as ebay. eBay has been hit or miss.
For reference sake, other places to get caps.
https://www.tedss.com/Capacitors
https://www.parts-express.com/cat/capacitors/68
https://meniscusaudio.com/product-category/capacitors/
https://www.madisoundspeakerstore.com/capacitors/
http://www.erseaudio.com/
https://www.mouser.com/new/nichicon/Nichicon-Audio-Caps/2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Mirage Omni S8 sub1 | Mirage Omni S8 Sub2 -
Well I decided to open up my bad amp and do an inventory of possible needed caps (there are actually very few). I took one of the big power caps out to get the numbers off them and figured while I was in there I'd deoxit all terminals. To my amazement, it now is dead silent upon start up and shut down! Guess I'd better do the other one now.All tube designed Hello Kitty boom box
@Lostsoul123
I concur, as others have mention you can use the same values or up in voltage and capacitance. I did a full rebuild of my Dad’s Sansui AU-6900 from 1975. The original spec called for 15,000uf modern replacements where much smaller and higher in capacitance. I replaced it with the closes physical match which was rated at 22,000uf at the same voltage and 1mm less in diameter.
I went a bit wild. All the other electrolytics are Elna or Nichicon premium audio grade.
Fully rebuilt, all the parts in the photo where replaced. Hopefully good for another 40 years.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Nice try Michaell, you've been reported as spam
alisjames121 reported spammer
Jowive2856 reported
Kroger the tinker bell has been reported.Political Correctness'.........defined
President of Club Polk -
Tellthebelll wants honesty. Ok, Taco Bell food is horrible, so bad I'd rather starve than eat it.Political Correctness'.........defined
