Rebuilding Amps
Lostsoul123
What are some good sources for audio quality capacitors? I'm considering at least replacing my power caps in my mono amps. They each have 4 15,500 @75v Phillips screw tops.
Any help would be appreciated.
All tube designed Hello Kitty boom box
Invisible aluminum wireless Phazer speaker wire
Free Spirit Teleport Preamp (Literally brings the artists into your living room)
1.44 JW Flux Capacitor Mono Amps
You can use higher or lower value capacitors, so long as you do not alter the voltage. EBay can be a good source, as well as Mouser.
https://www.ebay.com/itm/1x-30000uF-75V-Large-Can-Electrolytic-Capacitor-DC-105C-30000mfd-75VDC-30-000/132892290415?hash=item1ef0ff6d6f:g:F14AAOSw3ydVixHAThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Thanks John. I did look on eBay but didn't find what I needed plus not sure I want to trust something vintage that someone found on a shelf. Do electrolytics have a shelf life?Post edited by Lostsoul123 onAll tube designed Hello Kitty boom box
1.44 JW Flux Capacitor Mono Amps -
Lostsoul123 wrote: »Do electrolytics have a shelf life?
YES
That being said I've seen that brand use in many things. Best to just ask questions and go from there. Size is also a huge consideration as well.
Why? Why can you not go up in voltage? Many if us go up in voltage for electrolytic caps. Heck my Adcom preamp calls for 25 volt yet adcom themselves chose 35v for better ESR reasons in the end.
Not disputing Ryan I'm here to learn. Yes lower would certainly be a problem boom. -
Not disputing Ryan I'm here to learn. Yes lower voltage could certainly be a problem boom.
fixed
You most certainly can go up in voltage, but never down. For main filter caps in the power supply, you can also go up in capacitance, but never down.
Also pay attention to temperature rating and ESR...
I would also strongly suggest you avoid eBay for large filter caps - Chinese counterfeits are abundant. Further, a “new” capacitor selling on eBay May have been sitting on the shelf for 15 years. Buy from reputable sources like Mouser, Digikey, B&D Enterprises, Online Components, etc...Too much gear, too little time.... -
Thank you! So if I sent my amps to you for a refurb...All tube designed Hello Kitty boom box
I concur one can go up in voltage and capacitance.
I've had good luck finding what I needed at Tedss but not all of the time. I've used the reputable electronics places above as well as ebay. eBay has been hit or miss.
For reference sake, other places to get caps.
https://www.tedss.com/Capacitors
https://www.parts-express.com/cat/capacitors/68
https://meniscusaudio.com/product-category/capacitors/
https://www.madisoundspeakerstore.com/capacitors/
http://www.erseaudio.com/
https://www.mouser.com/new/nichicon/Nichicon-Audio-Caps/2.2 Office Setup | LG 29UB55 21:9 UltraWide | HP Probook 630 G8 | Dell Latitude | Cabasse Stream Amp 100 | Boston Acoustics VS 240 | AUDIORAX Desk Stands | Sub 1 - Mirage Omni S8 | Sub 2 - Mirage Omni S8
Well I decided to open up my bad amp and do an inventory of possible needed caps (there are actually very few). I took one of the big power caps out to get the numbers off them and figured while I was in there I'd deoxit all terminals. To my amazement, it now is dead silent upon start up and shut down! Guess I'd better do the other one now.All tube designed Hello Kitty boom box
@Lostsoul123
I concur, as others have mention you can use the same values or up in voltage and capacitance. I did a full rebuild of my Dad’s Sansui AU-6900 from 1975. The original spec called for 15,000uf modern replacements where much smaller and higher in capacitance. I replaced it with the closes physical match which was rated at 22,000uf at the same voltage and 1mm less in diameter.
I went a bit wild. All the other electrolytics are Elna or Nichicon premium audio grade.
Fully rebuilt, all the parts in the photo where replaced. Hopefully good for another 40 years.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Nice try Michaell, you've been reported as spam
alisjames121 reported spammer
Jowive2856 reported
Kroger the tinker bell has been reported.Political Correctness'.........defined
President of Club Polk -
Tellthebelll wants honesty. Ok, Taco Bell food is horrible, so bad I'd rather starve than eat it.Political Correctness'.........defined
