Using REW to measure SDA SRS 1.2
  • verb
    verb Posts: 10,176
    Well @dubseven I'm happy your getting some good advice! I have a set of first gen SRS's and I'm jealous! :smile:
  • Thank you all so much for the help!
    Does the rest of that measurement curve look "normal" for these speakers?
    nooshinjohn Posts: 25,928
    The second tweeter from the bottom is the one that produces the most sound in the 1.2TL, and should be the case with the 1.2 as well.
  • ptrooper
    ptrooper Posts: 501
    edited November 2019
    Yes,second from bottom is the brightest and will definitely sound muddy...,I'll bet You'll definitely be smiling even though the sl2000 are renowned to be a little bright at a certain frequency .
    Replacing the tweeters with the new rdo's makes a huge difference even to the bottom end!
    I have SDA SRS 's and the second from bottom is also brightest
  • ptrooper wrote: »
    Its about $500 to replace them all..... On top of the cost to send the crossovers out. Debating how much I want to sink into these things.
  • ptrooper
    ptrooper Posts: 501
    I have two sets of SRS's with full Abbot builds via VR3 mods and dont regret one cent!
    I'm going to be buried in them ,one for each of my children ,the miss's and me.
    My head will be sticking out though!kidding.
    If you can over time...."TL all the way"
    I won't say it again.....THEY ARE KEEPERS.
    Stock SRS's tweets usually shut down if the amp clips ie....over driven! yours might have this thingymajig( can't remember its name) bypassed as they do deteriorate the sound a little and apparently get worse the more they are activated to shut down and protect the tweets..
    A small under powered amplifier will do more damage than a good high powered amp!
    F1nut Posts: 51,781
    The 3rd tweeter from the top on the 1.2 is the main (full range) tweeter, so that would be the first one to cook.
  • Replaced the dead tweeters with SL2000s from some Monitor 10s I had for the garage.qh65qnrqlwvt.jpg
  • ptrooper
    ptrooper Posts: 501
    Get them set up and start grinning.
  • delkal
    delkal Posts: 764
    dubseven wrote: »
    That trace is starting to look more reasonable. Lets call it +/-5 dbs (I don't hear above 15,000hz anymore so the top end drop doesn't count for me). I know everyone strives for better (and you can) but there are a lot of speakers that won't even do that.
    I would take F1nuts advice that the 3rd tweeter from the top is the full range one. So if you have to replace any tweeters (and don't want to buy eight) get 2 RDO-194's and just replace them as a pair. RDO's are much better than the SL200s, are drop in replacements, and should flatten out the curve more. Of course 8 RDO-194s would sound better but I wouldn't put $500 to upgrade 8 tweeters just yet. I would replace just the two full range ones then think about replacing the caps.
    But from there the sky is the limit. Doing as full TL conversion with 8 new TL198s and a full recap/ conversion would sound awesome. But then comes the money part......
  • verb
    verb Posts: 10,176
    So I had to look it up, as I'm not familiar with REW. It's freeware? Donations of course, but Whoa! :smile:
    https://www.roomeqwizard.com/
  • delkal wrote: »
    dubseven wrote: »
    So, after doing some more reading, I can't tell if they are SDA SRS or SDA SRS 1.2 - they have the 13 bolt crossover plates, but blade/Blade interconnects. Any input?5dnithp8nvb2.jpg
  • ptrooper
    ptrooper Posts: 501
    Looks like SDA SRS.
    1.2's came with pin blade interconnects ,SDASRS are blade blade!.
    Some early 1.2'S came with the above face plate from previous left over SDASRS stock!
    The only real way to tell is to check the drivers model numbers.SDA SRS have 8 x 6503's in each enclosure.
    Make sure your amp is common ground using these.
    They'r still keepers B)
  • K_M
    K_M Posts: 1,632
    dubseven wrote: »
    That looks relatively close to the curve we got when we had REW hooked up a few years ago.
    If you close mic (about an inch or so away) the woofers and the passive radiator you can get a good idea of how they will sound minus the room interactions.
  • K_M
    K_M Posts: 1,632
    verb wrote: »
    It is an amazing tool for measuring speakers!
  • verb
    verb Posts: 10,176
    ptrooper wrote: »
    Looks like SDA SRS.
    Yep. SRS's like mine! :smile: Plenty of good technical information in the Vintage Speakers section here on CP.
    The only mod I made (thus far) was to swap out all the tweeters. Major improvement! :smile:
  • As others have stated, they are SDA SRS because of the blade/blade IC socket. Crossover plate is irrelevant. Polk never manufactured an SDA SRS speaker with a pin/blade IC, only the 1.2 and 1.2TL have the pin/blade IC.
    SDA SRS 2.3TL's
    SDA 2B TL's
    One can never say never when it comes to Polk, as they were notorious for raiding leftover parts until they were used up. I do agree that it is highly unlikely that the speakers are 1.2’s. Only pulling a couple drivers will tell for sure.
    F1nut Posts: 51,781
    There's an easy way to tell. Look at the sides of the end caps. If you see end grain they are SDA SRS. If you see face grain they are 1.2.
  • F1nut wrote: »
  • verb
    verb Posts: 10,176
    Hey Dub, need a pic of the side side, not the front side! That way you can tell if the End Caps are solid wood or veneer! :smile:
  • verb
    verb Posts: 10,176
    Here's mine. The sides show end grain, aka solid wood no veneer.
  • verb wrote: »
    Red Bull hasn't kicked in yet.... long night! :sq00rordhh3cq.jpg
  • verb
    verb Posts: 10,176
    Looks like veneer to me!
    F1nut Posts: 51,781
    That's face grain, which says 1.2, but the blade/blade says SRS. Another Polk mystery....lol
    F1nut Posts: 51,781
    dubseven wrote: »
    verb wrote: »
    Can you post a pic of the long wood strip on the side?
    Easiest thing would be to pull a driver from each column and see what the part numbers are. They are either very late SRS or very early 1.2’s. The drivers will tell all.
