Sound & Vision reviews the Legend L800
13
  • Nightfall
    Nightfall Posts: 10,083
    Got you. So the switch to MDF was a time frame thing not a best/better line thing?
    afterburnt wrote: »
    Village Idiot of Club Polk
    pitdogg2 Posts: 27,288
    Nightfall wrote: »
    Lower monitor series was all particle board but all SDA I believe was MDF once MDF became available.
    Someone correct me if I'm wrong. I seem to remember 1st gen. SRS as particle board.
  • verb
    verb Posts: 10,176
    Nightfall wrote: »
    I believe you are correct. IIRC when I swapped the tweeters on mine.
    verb wrote: »
    Nightfall wrote: »
    And had a lot more internal bracing IIRC
  • Emlyn
    Emlyn Posts: 4,818
    Right, high density particle board for the first ones. Cabinet construction was very different between the original SRS speakers and the final TL cabinets even though they look similar on the outsides. The originals had a more "lively" cabinet structure than the later ones. That can be beneficial for a speaker depending on what the designer is after and if they can properly adapt the material to do what they want. Spendor has kept on using veneered particle board for decades.
  • Thanks for the share. Straightforward review.
    What caught my eye most was a comment:
    These look like nice speakers but the BACCH4mac is a much more flexible and more advanced version of crosstalk cancelation. I have the BACCH4mac and cannot day enough good things about it.
    I got curious and holy **** for $5k and you still need speakers it had better be amazing. Fascinating system, it uses a freaking camera to track your head and dynamically apply crosstalk cancellation. Very advanced indeed, but more advanced or just a different even more expensive way of attaining crosstalk cancellation? I think yes.
    https://www.audiostream.com/content/bacch4mac-3d-audio-playback-system
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • ptrooper
    ptrooper Posts: 501
    Not to sure on this BACCH4mac when wanting to listen at a high sort of volume.
    Wouldn't the drivers have to handle twice as much information ,pushing and pulling the other channels information out of phase at the same time? The amp must be confused.
  • You're paying enough to not worry about such things. :D
    Up
    Down
  • K_M
    K_M Posts: 1,631
    ptrooper wrote: »
    It is not exactly out of phase so much, but the "Difference" signal, what is termed L-R and R-L, in other words everything that is not common to both channels.
    The opposite of Mono, which is the sum of both channels.
    There is actually very little difference signal information most of the time, in comparison to the Sum or Mono signal.
    If you wire a speaker across both Positive terminals (left and right) you will have the difference signal.
    It is interesting to listen to by itself.
    mhardy6647 Posts: 35,219
    edited November 2019
    K_M wrote: »
    ptrooper wrote: »
    Two thoughts occasioned by this post.
    Thought the First:
    https://forum.polkaudio.com/discussion/183376/turning-normal-speakers-into-sda-s/p1
    You did post to this thread, but (IMO, of course) it's a very interesting read vis-a-vis the bones of SDA :) so I thought I'd post the link as a reference/resource:
    Thought the Second:
    (from the above-referenced thread :p )
  • mpitogo
    mpitogo Posts: 520
    Polk Audio L800 Walnut in the house!
    WOW! But seriously talk to me in 100 hours. These are just FOOTB. Compares well to LSiM 707's which were previously my favorite.
    Did not mean to cross post this should have been in the other thread!
    Post edited by mpitogo on
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • JayCee
    JayCee Posts: 1,509
    Congrats....pics or, well, it didn't happen! :D Looking forward to your thoughts.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    FOOTB?
    mmmm... I thought I was wise in the ways of the interwebz...
  • mpitogo
    mpitogo Posts: 520
    Fresh out of the box. BTW I did not mean to cross post in two threads. Only meant it for the other but since replies already came in here ya go. Check the other thread for a different photo.
  • SIHAB
    SIHAB Posts: 5,584
    Still feels a little Alfred Hitchcock
  • ptrooper
    ptrooper Posts: 501
    first set out,,,serial number ?
  • mpitogo
    mpitogo Posts: 520
    Oh man, @ptrooper thanks for pointing that out, it turns out I have 2 right units. What a cluster f%^$#$@#. I thought they knew what they were doing since, when the brought in the first unit they said this is the “right” I did not pay attention when they brought in the left. I thought these are sold in patched pairs!?%$$!??/./
  • SIHAB
    SIHAB Posts: 5,584
    there you go. :s
  • smglbrth
    smglbrth Posts: 1,498
    Congrats on the L800's! However, I saw in another thread about the mixing up of the left/right and was wondering if this would be a problem. Looks like it is...
  • mpitogo
    mpitogo Posts: 520
    @smglbrth yes it is and major one! I disconnected the SDA cable and both where identical mirrors, the left drivers on both where playing. Left driver on the right is correct aimed at the sweet spot but left driver on the left is playing into space.
    VR3 Posts: 29,545
    Easy fix swap the wires to the other array
  • smglbrth
    IMHO, this kind of mistake on a $6000 pair of speakers should not happen, period...
  • mpitogo
    mpitogo Posts: 520
    @vr3 I would if these where the last two pairs sold on earth at 75% off.
    VR3 Posts: 29,545
    True that
  • mpitogo
    mpitogo Posts: 520
    @smglbrth yes, tell me about it. Who do you blame? The dealer for not rigorously checking? Or Polk audio for not making it more obvious. How are delivery folks supposed to know RC and LC. Or the customer for not paying attention?
    Even I did’t know until it (RC/LC) was pointed out. I hope other customers don’t go through this.
  • WLDock
    WLDock Posts: 3,073
    mpitogo wrote: »
    I say blame POLK. The boxes should have VERY LARGE and distinctive block "L" or "R" letters on all four sides so that warehouse personnel can easily see.
    If you can believe it, the same thing happened at the listening event at Abt Electronics back in October. They need to get this figured out and make sure all of the dealers are aware. The speakers should have never made it out the door. Even if the wrong parts were sent by Polk, the dealer should have caught it.
    IMO, you should complain to POLK and request that they get this under controller internally. They need to change their boxes and send out critical notices to all of their dealers. Not a way to launch $6000 speakers that have L& R pairs! Need to get out of their own way!
    mpitogo wrote: »
    The inescapable conclusion: Somewhere there's a pair with both speakers marked "WRONG".
    In seriousness, and in fairness -- gotta be one of the first shipments, right? Probably not really all that surprising. Birthing pangs, you know?
    Now, I'll finish up by being cynical. (me?!?)
    Back in the days before just in time inventory control, smart systems, etc., etc. -- when things were stupid, simple, and crude... probably never would've happened.
    It is unfortunate, though, given the hassle for all parties concerned and the fact that poor @mpitogo has to wait... again! :(
  • monepolk
    monepolk Posts: 1,154
    Different color boxes might help and noted that no two boxes of the same color should be shipped.
  • WLDock
    WLDock Posts: 3,073
    monepolk wrote: »
    Not hard at all to recognized a RED box with a big 'RIGHT' on all four sides and a BLACK box with a big 'LEFT' on it. Someone was not thinking about this. Even the way the different dealers have them listed on their sites can be confusing to some.
