Command Bar video blanks out every few minutes
rickliev
Every few minutes the video sources running through the command bar will go blank on the screen, while the audio continues to play. After a few seconds, the video returns. Very annoying! Anyone suffer from similar issues? Fix?
Answers
I command you to contact Polk customer service, dial 1-800-377-7655 select option 1.
Sound advice, barring any complications. -
I just came here for an answer to the same question. Although now it goes off and requires entire restart to get it back again... only to do it again a few minutes later. Tried combinations of different cables and ports to no avail. Then connected my Roku Ultra directly to the TV which works fine, so I know it’s the Polk soundbar (W/Alexa). It’s infuriating!
