Command Bar video blanks out every few minutes
Every few minutes the video sources running through the command bar will go blank on the screen, while the audio continues to play. After a few seconds, the video returns. Very annoying! Anyone suffer from similar issues? Fix?
Answers
    Clipdat Posts: 12,599
    I command you to contact Polk customer service, dial 1-800-377-7655 select option 1.
    Viking64 Posts: 6,679
    Clipdat wrote: »
    Sound advice, barring any complications.
  • mmm
    mmm Posts: 1
    I just came here for an answer to the same question. Although now it goes off and requires entire restart to get it back again... only to do it again a few minutes later. Tried combinations of different cables and ports to no avail. Then connected my Roku Ultra directly to the TV which works fine, so I know it’s the Polk soundbar (W/Alexa). It’s infuriating!
