Official SVS owners thread!
1141516171820»
    F1nut Posts: 51,972
    edited November 2019
    The Velodyne Optimum 8 sealed subwoofer is 11h x 10.5w x 14d and has a digital display, 4 pre-sets for easy switching from HT to music via the remote, -3dB is 26Hz/overall 16Hz, comes with a calibration mic and a high gloss black piano finish.
    The SB2000 is 14.6h x 14.2w x 17.1d. No display, no remote, no pre-sets, no calibration mic. Piano black costs extra. However, it does have a lower -3dB point.
  • jdavid
    jdavid Posts: 46
    Thanks, but planning on two Sb2000s.
  • mrloren
    mrloren Posts: 2,474
    jdavid wrote: »
    If you have time wait to see if the NSD subs come out this year. way better than SB1000 and almost as good as the SB2000
  • jdavid
    jdavid Posts: 46
    Thanks. Not familiar with this model— any reason to favor it over Sb2000?
    How does it compare ?
  • jdavid
    jdavid Posts: 46
    Should note will be used for only movies .
  • mrloren
    jdavid wrote: »
    Last few years SVS has sold a special model called PB or SB 12NSD starting in mid November or so. These are in between the 1000 and 2000 in specs and price. They are very nice subs.
    F1nut Posts: 51,972
    jdavid wrote: »
    Ah, in that case you're making the right choice going with SVS. The Velodyne would have been wasted.
    F1nut Posts: 51,972
    mrloren wrote: »
    jdavid wrote: »
    I bought my brother the SB12NSD for Christmas last year much to his wife's dismay....lol
  • jdavid
    jdavid Posts: 46
    Thanks guys will watch for the 12nsd.
    mrloren- what is the preferable distance for how far the S20s should be out from the wall behind them (due to the power port design primarily I assume) for best sound since I will be using them in a small room as front speakers for home theatre only. Appreciate the good advice I am receiving on the forum.
  • Mikey081057
    Mikey081057 Posts: 7,127
    Talk to the SVS guys.... they might think that 1 big sub might be better than duals...
    Garage | Polk Monitor 5B's
  • mrloren
    jdavid wrote: »
    I'd start at a foot. Great thing about stands is you can move them a bit
    Due to WAF he has to get two smaller subs. I agree a VTF3 or PB3000 would be a lot better for HT.
  • jdavid
    jdavid Posts: 46
    Well I can work on WAF for stands ( not for two larger ported subwoofers so need to stick with two sealed but room is small and corners should help).
    Any particular (WAF pleasing ) good stands people have used for S20s?
    Thanks as always to all.
  • Mikey081057
    Just don't make the mistake of settling for something that isn't going to satisfy and then have to take a loss later... 2 x sb2000's might look nice. SB3000's or 2 sb4000's would be great.... Not going ported for the HT is another compromise... Go big and deep... Is it the height of the ported subs that is an issue??? The holes?
    Skylan stands are nice and customizable... very sturdy as well.
    http://www.skylanstands.com
  • jdavid
    jdavid Posts: 46
    It is the size of the ported subs, and my hope was with two sb2000 or maybe two 12 nsd if SVS sells them later this month and in corner placement of both for a boost, and in a 8x15 room, using Audyssey XT 32 to adjust, the bass would be good - ( probably not to others on Forum levels). Certainly a major improvement over my single smaller def tech subwoofer!
    (I used up some of my WAF on my floor standers in the living room, which are remaining where they are despite a renovation.)
  • mrloren
    And the NSD subs are back
  • bms
    bms Posts: 182
    Sure hope a PC13 Ultra or a PC4000 comes on the outlet with special pricing. I’ve been waiting for quite some time...
    bms
    Family Room:
    Onkyo TX-RZ920
    Outlaw 2200 monoblock amps x 3
    Sony UBP-X700
    Sony A80J 77” OLED
    Polk LSiM 705’s
    Polk LSiM 706
    Polk LSiM 703’s
    Polk RTi4's
    Dual SVS PB13-Ultra’s
    PC13-Ultra
    Bonus Room:
    Onkyo TX-SR806
    PS3
    Panasonic TC-P42G10
    Polk RTi10's
    Polk CSi5
    Polk R50's
    SVS PB10-ISD
    For sale:
    Onkyo TX-SR603X
    I love my new SB3000! Best money I ever spent...donated my Polk Audio 12" sub to a friend...
  • Romo11
    Romo11 Posts: 101
    You will love it!
