Polk audio s60 or polk audio lsim705
Hi, I hope you can help me, I have a polk audio tsx 330 speaker and I want to change it for any of the options above, which one do you recommend? I will feel the difference compared to my former speakers. important to mention that I live in an apartment and listen to music vinyl
Thank
    F1nut Posts: 49,801
    The 705 is the better, more refined speaker, but your results will depend on what you are using upstream.
  • gabo123
    thanks for your answer i have a receiver cambridge audio topaz am10 i listen the music whith vynils.
    Will i feel the diference compared whit my tsx 330?
    F1nut Posts: 49,801
    edited November 2019
    With that integrated amp I think you'd be better off with the S60.
  • gabo123
    Than y what's is your opinion these s60? Will i feel the difference with tsx330
    Thank!!
    F1nut Posts: 49,801
    Yes, the Signature series are better suited for music.
  • Nightfall
    Nightfall Posts: 10,071
    Feel as in visceral bass or do you mean hear a difference?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • gabo123
    Hi nightfall, i mean hear a difference
    What is your opinion?
  • Nightfall
    Without a doubt.
    afterburnt wrote: »
  • gabo123
    Why is better for me s60??
    My tompaz amd 10 cambridge It does not work well with Lsim705?
    F1nut Posts: 49,801
    For the second time, your integrated amp is better matched to the S60.
  • rooftop59
    rooftop59 Posts: 7,981
    gabo123 wrote: »
    The signature series is designed to be easier to drive than the LSiM series. Your cambridge is a nice little entry level integrated, but its just not going to have the juice to drive the 705s. Honestly, bookshelf speakers like the s20 would probably be better suited, but if you insist on towers definitely the s series.
    Game Room 5.1.4:
    Bedroom 2.1
  • Nightfall
    rooftop59 wrote: »
    gabo123 wrote: »
    Use the money saved for a decent little sub and stands.
    afterburnt wrote: »
    nooshinjohn Posts: 25,100
    I am going to expand on this just a bit. Your Cambridge is a capable piece of kit, but is quite underpowered for the LSiM 705’s. If it is your intent to upgrade your integrated within the next 6 months to something more capable of giving them the power they need, I would get the 705’s.
    If you plan on staying with the Cambridge, then getting the S60’s would be the better choice.
