Preamp connection to Sub
acmf74
Hi,
I have a Rogue Perseus pre that I want to hook up to a Velodyne powered sub for music. I know I should connect it from the variable output section on the pre. The pre has 2 outputs but the sub only has 1 RCA input. Should I get a Y splitter from 2 to 1 or can I just plug in the 1 cable?
TIA
TIA
I've always used one of these in those situations:
Are the pre outs L and R?
This is the external amp for the Sub.
Thanks!
Connect the left and right variable pre out from your preamp to the left and right input on your sub amp labeled “from pre-amp.”
Is this one of those really old velodyne servo subs? I thought on those the amp was built in but the servo control until was external???Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Great thank you!
Yes, its an old Velodyne ULD-15 that was gifted to me. Supposedly it sounds very good. We shall see
Below is a link.
https://www.stereophile.com/subwoofers/velodyne_uld-18_amp_uld-15_subwoofers/index.html -
HA
typed to quickly. -
he knows how to push you're buttons ya pug-loving SOB!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
This is why I love this forum. Wealth of knowledge and it's members. -
Hes not the only one!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Post of the year....
But corrected so jimmy doesn't have an aneurysm...... Again!
Not even close*.
*This applies to both sentences.
How does one reach adulthood thinking that "I seen" is normal?
