Preamp connection to Sub
Hi,
I have a Rogue Perseus pre that I want to hook up to a Velodyne powered sub for music. I know I should connect it from the variable output section on the pre. The pre has 2 outputs but the sub only has 1 RCA input. Should I get a Y splitter from 2 to 1 or can I just plug in the 1 cable?
TIA
    Clipdat Posts: 13,101
    I've always used one of these in those situations:
  • afterburnt
    afterburnt Posts: 7,892
    Are the pre outs L and R?
  • acmf74
    acmf74 Posts: 937
    This is the external amp for the Sub.
    Thanks!
  • rooftop59
    rooftop59 Posts: 8,120
    Connect the left and right variable pre out from your preamp to the left and right input on your sub amp labeled “from pre-amp.”
    Is this one of those really old velodyne servo subs? I thought on those the amp was built in but the servo control until was external???
    Game Room 5.1.4:
    Bedroom 2.1
  • acmf74
    acmf74 Posts: 937
    edited October 2019
    Great thank you!
    Yes, its an old Velodyne ULD-15 that was gifted to me. Supposedly it sounds very good. We shall see :)
    Below is a link.
    https://www.stereophile.com/subwoofers/velodyne_uld-18_amp_uld-15_subwoofers/index.html
    Viking64 Posts: 7,767
    acmf74 wrote: »
    Supposedly it is supposed
    Do you work for The Department of Redundancy Department? :o
  • acmf74
    acmf74 Posts: 937
    HA
    typed to quickly.
    acmf74 wrote: »
    to
    Alright, now you're just teasing. :p
  • rooftop59
    Viking64 wrote: »
    acmf74 wrote: »
    to
    he knows how to push you're buttons ya pug-loving SOB!
    Game Room 5.1.4:
    Bedroom 2.1
  • acmf74
    acmf74 Posts: 937
    This is why I love this forum. Wealth of knowledge and it's members.
    rooftop59 wrote: »
    Viking64 wrote: »
    acmf74 wrote: »
    to
    You're?
    EEEGAD! :o
  • rooftop59
    Viking64 wrote: »
    rooftop59 wrote: »
    Viking64 wrote: »
    acmf74 wrote: »
    to
    You're?
    EEEGAD! :o
    Hes not the only one!
    Game Room 5.1.4:
    Bedroom 2.1
    pitdogg2 Posts: 27,767
    edited October 2019
    rooftop59 wrote: »
    Viking64 wrote: »
    acmf74 wrote: »
    to
    he knows how to push your buttons ya pug-loving SOB!
    Post of the year....
    But corrected so jimmy doesn't have an aneurysm...... Again!
    Not even close*.
    *This applies to both sentences.
    How does one reach adulthood thinking that "I seen" is normal? :p
