Dove Down the RTR Rabbit Hole
This may be a piece of junk but something to play with and just might have potential. Fortunately I got it for next to nothing.
I found a Concord MKII reel to reel deck, that I know nothing about and can't seem to find much online. It powers on and REW, and FWD work but Play and CUE don't because the pinch roller isn't pushing all the way up to capstan. Might be a simple fix. In any event I only paid $25 so it isn't a big loss if it is a dud.
Anyone happen to have any knowledge or info on this deck?
Stan
Main 2ch:
HT:
Other stuff:
    nooshinjohn Posts: 25,928
    That is one rabbit hole I avoid like the plague. I appreciate R2R from a very long distance.
  • skrol
    skrol Posts: 3,452
    Yeah, I probably should too. This thing seems to almost work except I think it needs a pinch roller. Might be tough to impossible to find a good one.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    SCompRacer Posts: 9,112
    edited October 2019
    Pop the hood and poke around. Levers, linkage, springs, solenoids, belts, clutches....a smorgasbord of mechanical stuff.
    Jasper loves it when the take up reel is full and that leader slaps around.
  • verb
    verb Posts: 10,176
    I love mechanical stuff! Looks very cool! :)
    mhardy6647 Posts: 35,029
    What's wrong with the pinch roller?
    They can often be rescued if they're shiny or sometimes even if they're hard... and there are folks who will (ahem) re-rubber them.
    edited October 2019
    PS, Jasper looks somewhat disdainful to me...
    I will mention that ol' Zappa (the Cat -- as opposed to Zappa the Iconoclast)
    once effected scission of a reel to reel tape playing (unattended -- my fatal mistake) in our living room, long ago now.
    The spinning reels and the dulcet tones of the Beatles proved too much for him to resist.
    No photo of the event (nor even its aftermath) is available, unfortunately -- so here he is, sneakin' up on an unsuspecting Electrovoice 15TRXB coaxial speaker.
    15230618812_61ea6849f0_c.jpgEV15TRXBflipside by Mark Hardy, on Flickr
    Boy-o-boy -- I did a terrible job parsing this thread! Sorry!! :(
    @skrol (the OP) is talkin' about a Concord Mk II -- Jasper distracted me! :p
    edited November 2019
    Jasper is good at that! He doesn't like when I stop the reel before the leader slaps around.
    How did the woofer fare out? Zappa looks like he was assuming lunge mode.
    My deck is a Pioneer RT-71.
    Viking64 Posts: 7,559
    skrol wrote: »
    Dove
    Dove?
    long "o", bub... long "o"
    -- or diven, if you prefer your verbs irregular.
    PS Note that I did not say "if you prefer @verb [.s.] irregular". :#
    (FWIW)... more on the Concord Mark II.
    source: http://reel2reeltexas.com/vinAd70.html
    This one is much more generic looking than the Mark IV -- other than the roller to the left of the headblock, this one looks quite Sony-esque. That said, lots of late '60s -early '70s Japanese-made decks looked a lot like this, too. :p
    so... did anyone ever answer the original question from @skrol about the lazy pinch roller?
    I mean, I addressed the shiny/hard roller 'issue', but upon re-reading the OP, I got the impression that lack of engagement was even more of an issue in this particular case.
    IME/IMO the typical problem with elderly single-motor, mechanical control decks like this Concord is... gunk. Gunked-up mechanicals, to be more precise. B)
    CLA (Cleaning, Lubrication, and Adjustment) is indicated -- particularly C and L (as opposed to D and C :p ) in the present case.
    Also IME (and FWIW) -- a pinch roller that won't quite engage can sometimes be encouraged into position and engagement with a little... umm... digital manipulation.
    I've got a coupla Sony single-motor decks here that need a little help to get goin' in this regard (and in full disclosure) -- like this TC-377, for example :#
    16102128209_35069f8b58_k.jpgSony TC-377 by Mark Hardy, on Flickr
  • verb
    verb Posts: 10,176
    Lol! I've been called worse! :)
  • skrol
    skrol Posts: 3,452
    Thank you for the info. I got it working. I had removed the pinch roller and saw that the mechanism was moving all the way into position, reinstalled and it was good. After that I cleaned and demag'd the heads and cleaned cabinet. It looks pretty good. I still need to clean and lube the mechanicals. What lube do you suggest?
    It came with about 3 hours of Christmas music too.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • headrott
    headrott Posts: 5,496
    Let me ask my brother about this deck. He is an "expert" at Reel 2 Reel decks. Give me some time though, please.
    Appropriately timed on the Christmas music too!
    What exactly are you needing to lube? It makes a difference in suggesting what to use.
  • I have torn into many machines over the years, with the biggest culprit being hardened grease on the linkages. What I have used after cleaning the linkages, is lithium grease. It comes in a spray, and can be purchased at a auto parts store, or even Wal-mart. I spray some product into a paper cup, and use Q-tips to spread it on the linkages, should last for years.
    Nice to hear the deck responded well to treatment :)
    Yeah, my gut feeling was (white) lithium grease (e.g., GC "Lubriplate") -- but I am no expert on these things (i.e., at the nuts and bolts and grease level)!
