Dove Down the RTR Rabbit Hole
skrol
This may be a piece of junk but something to play with and just might have potential. Fortunately I got it for next to nothing.
I found a Concord MKII reel to reel deck, that I know nothing about and can't seem to find much online. It powers on and REW, and FWD work but Play and CUE don't because the pinch roller isn't pushing all the way up to capstan. Might be a simple fix. In any event I only paid $25 so it isn't a big loss if it is a dud.
Anyone happen to have any knowledge or info on this deck?
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
That is one rabbit hole I avoid like the plague. I appreciate R2R from a very long distance.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Yeah, I probably should too. This thing seems to almost work except I think it needs a pinch roller. Might be tough to impossible to find a good one.Stan
Main 2ch:
HT:
Other stuff:
Reach out to @KennethSwauger
Pop the hood and poke around. Levers, linkage, springs, solenoids, belts, clutches....a smorgasbord of mechanical stuff.
Jasper loves it when the take up reel is full and that leader slaps around.
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I love mechanical stuff! Looks very cool!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Quite possibly Pioneer OEM, I suspect.
The deck, not the kitteh, that is.
https://www.hifiengine.com/manual_library/pioneer/t-6600.shtml
http://www.kallhovde.com/pioneer/1971-cat.pdf
EDIT: see also: http://www.kallhovde.com/pioneer/tricomp/Audio/RT/RT-71.pdf
What's wrong with the pinch roller?
They can often be rescued if they're shiny or sometimes even if they're hard... and there are folks who will (ahem) re-rubber them.
PS, Jasper looks somewhat disdainful to me...
I will mention that ol' Zappa (the Cat -- as opposed to Zappa the Iconoclast)
once effected scission of a reel to reel tape playing (unattended -- my fatal mistake) in our living room, long ago now.
The spinning reels and the dulcet tones of the Beatles proved too much for him to resist.
No photo of the event (nor even its aftermath) is available, unfortunately -- so here he is, sneakin' up on an unsuspecting Electrovoice 15TRXB coaxial speaker.
EV15TRXBflipside by Mark Hardy, on Flickr -
Boy-o-boy -- I did a terrible job parsing this thread! Sorry!!
@skrol (the OP) is talkin' about a Concord Mk II -- Jasper distracted me!
mhardy6647 wrote: »Jasper distracted me!
Jasper is good at that! He doesn't like when I stop the reel before the leader slaps around.
How did the woofer fare out? Zappa looks like he was assuming lunge mode.
My deck is a Pioneer RT-71.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
long "o", bub... long "o"
-- or diven, if you prefer your verbs irregular.
PS Note that I did not say "if you prefer @verb [.s.] irregular".
(FWIW)... more on the Concord Mark II.
source: http://reel2reeltexas.com/vinAd70.html
This one is much more generic looking than the Mark IV -- other than the roller to the left of the headblock, this one looks quite Sony-esque. That said, lots of late '60s -early '70s Japanese-made decks looked a lot like this, too.
so... did anyone ever answer the original question from @skrol about the lazy pinch roller?
I mean, I addressed the shiny/hard roller 'issue', but upon re-reading the OP, I got the impression that lack of engagement was even more of an issue in this particular case.
IME/IMO the typical problem with elderly single-motor, mechanical control decks like this Concord is... gunk. Gunked-up mechanicals, to be more precise.
CLA (Cleaning, Lubrication, and Adjustment) is indicated -- particularly C and L (as opposed to D and C
) in the present case.
Also IME (and FWIW) -- a pinch roller that won't quite engage can sometimes be encouraged into position and engagement with a little... umm... digital manipulation.
I've got a coupla Sony single-motor decks here that need a little help to get goin' in this regard (and in full disclosure) -- like this TC-377, for example
Sony TC-377 by Mark Hardy, on Flickr -
mhardy6647 wrote: »long "o", bub... long "o"
Lol! I've been called worse!
Thank you for the info. I got it working. I had removed the pinch roller and saw that the mechanism was moving all the way into position, reinstalled and it was good. After that I cleaned and demag'd the heads and cleaned cabinet. It looks pretty good. I still need to clean and lube the mechanicals. What lube do you suggest?
It came with about 3 hours of Christmas music too.
Stan
Main 2ch:
HT:
Other stuff:
Let me ask my brother about this deck. He is an "expert" at Reel 2 Reel decks. Give me some time though, please.
Appropriately timed on the Christmas music too!
What exactly are you needing to lube? It makes a difference in suggesting what to use.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I have torn into many machines over the years, with the biggest culprit being hardened grease on the linkages. What I have used after cleaning the linkages, is lithium grease. It comes in a spray, and can be purchased at a auto parts store, or even Wal-mart. I spray some product into a paper cup, and use Q-tips to spread it on the linkages, should last for years.
Nice to hear the deck responded well to treatment
Yeah, my gut feeling was (white) lithium grease (e.g., GC "Lubriplate") -- but I am no expert on these things (i.e., at the nuts and bolts and grease level)!
https://youtu.be/Q0dNhDbbrgY
