Help. Need to know how to setup my polk audio rtia9 speakers with my receiver
I recently bought a sony str dn1040. Will this receiver work for the rtia9? How do you set it up?
  • Nightfall
    Nightfall Posts: 10,083
    edited October 2019
    It will work, yes, but that's way too weak of an AVR for those speakers. 22 pounds, 100 watts with two channels @ 6 ohm so 8 ohm rating is even less.
    Don't crank it. Ever.
    Red speaker post to red speaker terminal, black to black, L to R with speaker wire. Source (whatever you're hooking up) to input on the AVR with a pair of RCA interconnects.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Nightfall wrote: »
    Thanks. What do you recommend to increase power?
  • rpf65
    rpf65 Posts: 2,127
    There isn’t anything you can do with that AVR to increase power. You would need to replace it with a different that has pre outs.
    F1nut Posts: 51,912
    ripdive wrote: »
    No!
