Anyone messed around with the Mconnect app for Tidal ?
gyosa
gyosa Posts: 699
edited October 2019 in Going Digital
Just found it for IOS ....
Looking at MQA’s website , Mconnect is a “MQA partner”.
It has Tidal and Quobuz built in to it ...
From what I can see , using it last couple days , it it will send MQA files over UPnP to your player at a minimum 24 bit , 48khz/44.1khz ..... better than the native 16 bit , 44.1khz that is native to my players integrated Tidal app - even when playing a MQA file .... my player is not MQA compatible - yet .....
Dunno how many unfolds the app is doing - if any at all - but the bitrate and sampling is definitely higher - and noticeably improved to my ears ....
Anyone ?
Bk
Dayens Ampino , Yamaha wxc-50 , Polk SDA 1c’s ( my first love .. ) , Kimber Kable 4TC, Sony 42” - BEDROOM
B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
Parasound A21, Eversolo DMP-A8 , Yamaha wxc-50 , Kimber Kable 4vs , Salk Supercharged Song towers ( difficult choice between these and my family if I had to choose ... 😩 ) , Sony XBR-A8F 65” OLED - DEN , MAIN RIG
PS Audio S300 - sitting in the closet for now …
Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sharp 65” TV - PATIO
  • jeremymarcinko
    Yes I do this very thing. I think that Mconnect unpacks the MQA file and sends a 24bit PCM version to the network streamer.
  • gyosa
    gyosa Posts: 699
    edited October 2019
    Jeremy ,
    I’ve been using the free version ....
    Any functionality differences between it and the paid version ?
    What streamer are you using ?
    I just ordered a Cambridge 851n....
    The Tidal integration is better than what my streamer has ....
    Do you have any tips for me ?
    Bk
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    edited October 2019
    The easiest thing is to do search for your music in the tidal app rather than in Mconnect. Add them to a playlist then locate that playlist in Mconnect. Way easier than to search music in Mconnect.
    I’m also using the lite version.
