BI-amping my A9's , will that result in much difference ?
I happen to have an extra amp and I was going to get a 2nd set of speakers but then again..dont really need that. i just run a 2.1 system
so I thought maybe Bi-amp the A9's ..but how much better will it be if I do that? what would I need to do that besides 2 amps?
  • daddyjt
    daddyjt Posts: 3,056
    Depending on the amplifiers in question, the difference could be substantial. I would certainly give it a try....
    ― Aleksandr Solzhenitsyn
  • since I dont have an electronic crossover and my amps dont have any filtering I am not going to attempt it. Im sure I would end up blowing a tweet or mid.
  • rooftop59
    rooftop59 Posts: 8,121
    gentlejax wrote: »
    that's probably best. You can't level match unless they are the same amps, and you will just be sending way more power to the tweets than needed. If you want more power sell both and get a beefier amp...
    Game Room 5.1.4:
    Bedroom 2.1
  • its not so much needing power it was just had an extra amp. I dont think ill do it though
  • daddyjt wrote: »
    one of your favorites...m500t
  • There’s a couple of good 200 W per channel amp’s for sale in the classifieds right now.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
    tonyb Posts: 33,069
    Forget the bi-amping, either keep the extra amp as a back-up, or sell it and use the cash to upgrade something else in the system.
  • daddyjt
    gentlejax wrote: »
    daddyjt wrote: »
    If you have a pair of 500t, do it. No level matching issues, and it’s not about giving the tweeters more power than they need, but more about freeing the tweeters from sharing power with the low end. As you push towards clipping, your tweeters will thank you for not being starved.
    tonyb Posts: 33,069
    daddyjt wrote: »
    gentlejax wrote: »
    daddyjt wrote: »
    As you push towards clipping ?? The tweets will thank you...by not working.
  • daddyjt
    tonyb wrote: »
    daddyjt wrote: »
    gentlejax wrote: »
    daddyjt wrote: »
    All due respect, I should have been more clear -
    As an amp runs out of power, it goes into “clipping”, whereby the tops of the wave forms that comprise the music are “clipped”, as the amp does not have enough power to completely form the wave. These clipped waves are seen by the speaker as short bursts of DC current, becoming longer as the amp is driven harder into clipping (more of the wave is clipped).
    DC current in a speaker is extremely dangerous, as it radically increases heat. These effects are disastrous to tweeters (they are bad for woofers and mids, but not nearly as bad as for tweets). This added heat can quickly melt the glue that forms the voice coil of the tweeter, thereby ruining it.
    The low frequency demands of music are most commonly what drives an amp into clipping, as the power required to move the woofers is exponentially greater than that required to move the small drivers of tweeters. In short, the bass causes the clipping, but the tweeters pay the price.
    bi-amping allows the tweeters to be isolated (as they have their own amp) from the effects of woofers driving their amplifier into clipping. The result is better sound, and protection for your tweeters.
    Just my own experience... take it for what it’s worth.
    tonyb Posts: 33,069
    Bi-amping doesn't necessarily isolate the tweets.
    If you have 2 amps, being driven by one volume control, your sending the same thing to each amplifier. Where most get into trouble with bi-amping, is they think they can crank on the volume dial because of all the power available. This usually results in overdriving the tweets, which is much easier to do than the woofers.
    tonyb Posts: 33,069
    I do agree though, that the woofers cause the issue and the tweets pay the price. Just my opinion, but bi-amping causes more issues than it's worth. Get a good amp, and know when to turn the volume down, and you'll never have to worry about blown tweets.
    In 40+years, I've never blown a tweet in any speaker. Blown tweets are usually from user error.
  • daddyjt
    In my earlier days, before I could afford a suitable single chassis amp, I biamped a few pair of speakers, but especially my Infinity Kappa 9 pair. The woofers on those speakers are sheer torture for an amplifier, and they can clip an amp very easily. Biamping was the way to go then, but now I have the McCormack and the Mark Levinson, either of which have no problem taming those (or any other speakers i own).
    I completely agree on blowing tweeters (or any other drivers, FTM) being user error. The only tweeter I’ve ever blown was in my teen car audio days - and yes, completely user error;-)
