This really bugs me and the wife. Suggestions anyone
Last resort, buy an anteater. Be the first on your block. Though with a tongue like that, Russ may never leave your house when he visits.HT SYSTEM-
lsi 9's -
Oh jeez, that one was low Tony!2 Channel in my home attic/bar/man cave
2 Channel Focal Kanta 3 I Modwright SWL9.0 Anniversary Pre I Modwright PH9.0X I Modwright KWA-150SE I VPI Prime Signature w/ Soundsmith Zephyr MIMC I Lumin U2 Mini I North Star Designs Intenso DAC I Audience OHNO ICs/Audience Furutech FP-S55N and FP-S032N Power Cables/Acoustic Zen Satori I Isotek Sirius -
Scratching my head on this one for sure!
I like the idea of compressed air, but perhaps one of those cans that have a tube on the end of it. Maybe find an extension tube to be able to sneak it in between the screens.
The suction cup idea is a good one too. Pull the protective screen out, with some compressed air.
That's all I got.
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
....I've had a bee stuck inside my tail light cover on the car, for 8 years now and it's still there.
Wow, lazy much, Tony? What, no Phillips screwdrivers in Chicago?
Yeah -- I mean, how do you think that bee ended up in that tail light, anyway?
lsi 9's -
teekay0007 wrote: »
They have been banned in Illinois in response to a series of drive-by screwings by a bunch of flat-heads...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Failed attempt. Probably shouldn't have used a hammer!
I considered suggesting a centrifuge -- it'd need to be a pretty big centrifuge. On the plus side, it wouldn't have to spin too fast...
It's a long process but I've got the little bug down a couple of inches using a small suction cup and a electric tooth brush until it quit dropping down assuming once it dries up a bit more it will continue to drop. It seems the farther down the screen you go, the harder it is for the suction cup to pull the screen away from the screen.Home Theater
I simply cannot wait to see the YT video.
In seriousness, good for you -- does your with think you're nuts or a prince
among men for your dedication to dealing with this scourge?
That makes sense Steve as the closer to the edge the tighter it would be. Can you push against it to flatten it more?
Ivan that's what I'm thinking, but I want to make sure that ant is dried up so I dont smear bug juice in between as that would require taking it apart to clean that mess up.Home Theater
gotcha
Just curious. Can you see this bug when actually watching TV. I assume you are at least 6’ away when watching.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Put a spider in the TV??Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
That tv will always have legs 🐛"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
The spirit of innovation -- outside the box thinking.Put a spider in the TV??
Well done!
….and I dated her in H.S. I believe the ethnic background of that fly was Spanish.
lsi 9's -
Do not do this... the closer to the edge, the more sensitive the glass becomes. Some sets will crack faster than you can think possible from the slightest touch.That makes sense Steve as the closer to the edge the tighter it would be. Can you push against it to flatten it more?
Wait it out a bit Steve. The heat generated from the screen should dry it out soon if it isn't already.
Once it gets close to the edge, like John said, you don't want to fudge with the screen anymore. Be better to try and remove the framing from that part of the screen to remove any pressure and then wiggle it down by tapping it slightly.HT SYSTEM-
lsi 9's -
The ant was probably wondering,"how the f&@(k did I get in here"?? Check and see if he left a trail of bread crumbs.See my profile for list of gear.
The prehistoric ants trapped in amber (fossilized tree resin) wondered the same thing, albeit in inscrutable prehistoric ant languages...
I'm done for a while the big deck project that the wife made me commit to starts monday so that ant is the last thing on her mind shes got other stuff to tend to now and shes letting me know about it. I guess that ant will have to wait.Home Theater
