This really bugs me and the wife. Suggestions anyone
    tonyb Posts: 32,906
    Last resort, buy an anteater. Be the first on your block. Though with a tongue like that, Russ may never leave your house when he visits.
  • stangman67
    stangman67 Posts: 2,185
    Oh jeez, that one was low Tony!
  • verb
    verb Posts: 10,176
    Scratching my head on this one for sure!
    I like the idea of compressed air, but perhaps one of those cans that have a tube on the end of it. Maybe find an extension tube to be able to sneak it in between the screens.
    The suction cup idea is a good one too. Pull the protective screen out, with some compressed air.
    That's all I got. :)
  • teekay0007
    teekay0007 Posts: 2,289
    tonyb wrote: »
    ....I've had a bee stuck inside my tail light cover on the car, for 8 years now and it's still there.
    Wow, lazy much, Tony? What, no Phillips screwdrivers in Chicago?
    txcoastal1 Posts: 13,132
    teekay0007 wrote: »
    tonyb wrote: »
    Careful Teekay, Tony's in the concrete business, not nuts and screws ;)
    mhardy6647 Posts: 33,020
    Yeah -- I mean, how do you think that bee ended up in that tail light, anyway?
    B)
    tonyb Posts: 32,906
    teekay0007 wrote: »
    tonyb wrote: »
    Lets just say it's an experiment. :)
    nooshinjohn Posts: 25,089
    teekay0007 wrote: »
    tonyb wrote: »
    They have been banned in Illinois in response to a series of drive-by screwings by a bunch of flat-heads...
  • verb
    verb Posts: 10,176
    Failed attempt. Probably shouldn't have used a hammer! :)
    I considered suggesting a centrifuge -- it'd need to be a pretty big centrifuge. On the plus side, it wouldn't have to spin too fast...
    B)
    gudnoyez Posts: 8,060
    edited September 2019
    It's a long process but I've got the little bug down a couple of inches using a small suction cup and a electric tooth brush until it quit dropping down assuming once it dries up a bit more it will continue to drop. It seems the farther down the screen you go, the harder it is for the suction cup to pull the screen away from the screen.
    gudnoyez wrote: »
    I simply cannot wait to see the YT video.
    In seriousness, good for you -- does your with think you're nuts or a prince
    among men
    for your dedication to dealing with this scourge?
    pitdogg2 Posts: 24,549
    That makes sense Steve as the closer to the edge the tighter it would be. Can you push against it to flatten it more?
    Ivan that's what I'm thinking, but I want to make sure that ant is dried up so I dont smear bug juice in between as that would require taking it apart to clean that mess up.
  • BlueFox
    BlueFox Posts: 15,251
    Just curious. Can you see this bug when actually watching TV. I assume you are at least 6’ away when watching.
  • mrbiron
    mrbiron Posts: 5,711
    Put a spider in the TV??
  • That tv will always have legs 🐛
    mrbiron wrote: »
    The spirit of innovation -- outside the box thinking.
    Well done!
  • Willow
    Willow Posts: 10,869
    mrbiron wrote: »
    There was an old lady who swallowed a fly....
    tonyb Posts: 32,906
    Willow wrote: »
    mrbiron wrote: »
    ….and I dated her in H.S. I believe the ethnic background of that fly was Spanish. :)
    Do not do this... the closer to the edge, the more sensitive the glass becomes. Some sets will crack faster than you can think possible from the slightest touch.
    tonyb Posts: 32,906
    Wait it out a bit Steve. The heat generated from the screen should dry it out soon if it isn't already.
    Once it gets close to the edge, like John said, you don't want to fudge with the screen anymore. Be better to try and remove the framing from that part of the screen to remove any pressure and then wiggle it down by tapping it slightly.
  • TEAforONE
    TEAforONE Posts: 1,001
    The ant was probably wondering,"how the f&@(k did I get in here"?? Check and see if he left a trail of bread crumbs.
    TEAforONE wrote: »
    The prehistoric ants trapped in amber (fossilized tree resin) wondered the same thing, albeit in inscrutable prehistoric ant languages...
    B)
    I'm done for a while the big deck project that the wife made me commit to starts monday so that ant is the last thing on her mind shes got other stuff to tend to now and shes letting me know about it. I guess that ant will have to wait.
