MY IMPRESSION OF THE 707/2CH
707's...Pretty darn good in 2ch Mode
I've been dragging my heels on getting my set up fully dialed in. I still need to drag my acoustic foam out and adorn the walls behind the center and two mains.
After jamming out on my A9's for close to 10 years after upgrading from Monitor 70's (remember those and the new egg deals?), These 707's which I thought would never grace my set up, became obtainable through one of those psycho crazy deals from Adorama.
While owning two pairs of 703's and knowing that the top section of the 707 is a 703, it was very tough to justify a 707 purchase. Well I'm here to tell you right now, the 707 and the 703 does not present the same soundstage!!!
And though I would not have paid full boat for a pair (707's), I was prepared to pay a couple hundred more for the pair than what I ended up with, and, there would have been no remorse, I would have gladly paid the extra (300) and been darn grateful! But just as I was about to pull the trigger, the deal, IMO that surpassed all deals fell right into my lap.....like my grandpa used to say, "even a blind hog finds an acorn now and then".
So what then, makes the 707 so much better?? Mind you, I spent years grooming my A9's to do what the majority in the Polk world claimed with authority could not be....."the A9's are superb home theater speakers but not good for 2ch"...."the A9's rule for H.T. but are just too bright to be decent 2ch speakers".....and so on and so forth.
FWIW, I experimented long ago with amplification, using greatest hits from Chicago and specifically, blaring horn sections. Results: A9's run directly from Onkyo AVR 2ch rated 135wpc...eardrum piercing brightness. A9's run from Emotiva XPA-3 rated 200wpc....eardrum annoying brightness. A9's run from Emotiva XPA-2 rated 300wpc...bingo, no more brightness, feed them more headroom, tame the brightness.
Fast forward to, proper placement, room treatments, all shielded and quality cables at every point in the signal path from the source to the amp, 450wpc and by golly, a pair of A9's that became very impressive 2ch speakers, so much that my wife (ex) decidedly chose them over the 703's in an A/B comparison, and this girl has a great ear, never did notice when I made a physical change, but always knew when I would make an audible change. Without me mentioning it, she would call me out every time, asking me, "it sounds different, what did you do?"
Friends would come over and after a 2ch demo, would always respond the same way every time...."wow, that sounds awesome"
So why the big build up??? To make a point about the effort and achievement on yielding a result that majority dismissed as unobtainable and what's about to follow.
The 707's arrive, get unboxed and replace the A9's which have replaced the 703's and are now pulling Rear Surround duty. The 707's are connected and play 2ch and movies for a few days.
Next is MultEQ XT32 set up. With the 707's toed in so the axis crosses a foot and a half behind the main listening position and begin with some CD's, source is the Emotiva ERC3 connected via balanced XLR's to Marantz 8802, connected to Emotiva Reference XPA-DR3 via balanced XLR's.
Without room treatments, the 707's opened up the soundstage wider and deeper than what the A9's had produced. And though the A9's did a great job of imaging and detail, the 707's do a better job of separation of instruments.
This is all pretty much from initial impression, I see great things coming from these 707's, very happy with my decision to make a blind buy and Highly recommended, not just for home theater speakers, but I would recommend the 707's to operate exclusively for a 2ch effort.
Set up:
Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • dolbyd
    dolbyd Posts: 430
    edited September 2019
    Awesome. Having the DR3 and A9s I agree with your assessment of them together. If you spend the time you can get the A9s sounding amazing.
    I have seen my setup and @Inspector 24 setup go way beyond what most people think the A9 are capable of. His system had a few years on mine and he had it down. Sounds great.
    That being said the 707s will be much better. I am happy that he is picking up a set. I will be enjoying his setup for sure, and probably wishing I had bought a set.
    Enjoy!
    Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
    Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
    Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
    Patio- SDI Atrium8 x3, Emotiva A-100 amps x3
  • dromunds
    dromunds Posts: 10,135
    Thanks for the review, Geoff.
    bump
    bump
  • Geoff4rfc
    Geoff4rfc Posts: 2,898
    dromunds wrote: »
    tonyb wrote: »
    bump
    My pleasure....and if I had the room and at these crazy low prices, I may have even sprung for a set of 707 wides………..remember this set up from 2011 with four A9's??
    Set up:
    Crazy sheet right there my man.
    bump
  • WLDock
    WLDock Posts: 3,073
    How big is your room? Have you noticed any bass bloat that some speak of regarding these in some small to medium sized spaces? Good to hear that you are liking them.
    mhardy6647 Posts: 35,149
    looks good to me.
  • Geoff4rfc
    WLDock wrote: »
    My space is 15' x 26ish'. I did notice some bloat right at first but they have smoothed out.
    I do notice heavier LFE in the back of the room about 3' behind the Rear surrounds.
    Set up:
  • WLDock
    WLDock Posts: 3,073
    ^^OK, that's interesting to hear. I was thinking long and hard about them as the 707's are the one's I always wanted. We'll see if the 705's go on sale again as my room is only about 13' x 18' and opens to a kitchen and hallway. I get pretty good low end reinforcement.
