Monitor 7C crossover question
vulcan
I recently bought a set of the Monitor 7C speakers and hooked up yesterday, everything sounded ok. So i pulled out the crossovers to verify the components match the wiring schematic. I am going to upgrade the caps/resistor. Today I noticed the Polyswitch appears to have been clipped off on both. Unless a jumper has been placed on the circuit then that tweeter circuit should be open. Looking at the boards I cant tell. Anyone see a possible jumper, if not can you suggest something? Ideas? There is no fuse on the terminal cups.
Thanks!
Thanks!
Polk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II
Yep poly is M.I.A.. I do see a jumper right next to the resistor. That clipped item has me perplexed. It looks to me to far spaced for the poly.
Looks like they clipped the poly close to the disk & just twisted & soldered its leads.
Bingo!
See this:
Tony you are correct, I see an original 7c crossover on Ebay with the Polyswitch in place. I now see where it went, I was looking at the wrong points(clipped lead ends).
So replacing the 2 ohm resistor, i want to go with a 2.5 without the polyswitch.
Getting ready to order new caps from Parts Connexion. thanks
Another Polkie must have owned these, lol. Happy Friday everyone!
https://ebay.com/itm/Polk-Audio-Monitor-Series-7-Crossover-ONE-1/163858089778?hash=item2626b40732:g:t68AAOSwI39deVHbPolk Audio SDA 1C, Klipsch Legend KLF 20, Klipsch Chorus II -
Bingo!
See this:
exactly Tony. But his does have something soldered in the other holes that had me perplexed as to what was there. -
I took a closer look at the underside. That's where the Black and White wires from the binding posts attached and were soldered in and the excess clipped off..I should have saw that earlier. I just assumed at first that was where that Polyswitch switch was..
thanks. Any other advice/help with the crossover upgrade is welcome.
don't use Solen. Sonicaps or Clarity are very good match.
I'm a big Sonicap fan. -
Thanks for the info. I ordered Clarity/Mundorf caps, these were more in line
with my "budget". I update binding posts with some from Parts Express.
Several years ago I purchased some Klipsch Forte II and ordered the crossover kit
from Bob Crites, they were mostly Sonicaps. They sound good.
Have a great weekend!
