New Sunfire Sig
  • rebelsoul
    rebelsoul Posts: 756
    edited September 2019
    I talked to the guy that did work on it and he has been working on carver and sunfire amps for 30 years.
    Viking64 Posts: 6,683
    Rebel souls
    Deserters we are called
    Chose a gun and threw away the sun.....fire
    Bad company
    I can't deny
    Bad company
    Till the day I die
  • rebelsoul
    So did the Sig 1 come with the gold posts ? Is this a upgraded sig 1?
    There is no hum,whine or noise. Background is dead silent. I am very happy with Amp
  • rebelsoul
    Can this be a in between model? Had a couple of Carver m 1.5t s and they had different face plates. And writing was different?
    rebelsoul wrote: »
    I love lamp.
  • rebelsoul
    This is the back of one I found on ebay
  • rebelsoul
    The one I bought
  • Nightfall
    Nightfall Posts: 10,071
    rebelsoul wrote: »
    So did the Sig 1 come with the gold posts? Is this an upgraded sig 1?
    That amp you have actually has a flaw in that someone ACTUALLY grabbed the WRONG back plate to build the amp. It has listed by the IEC power input socket 10amp 250v fuse. THAT IS COMPLETELY WRONG. It should say 15amp 250v fuse. If it is running a 10amp fuse it will NEVER run correctly or to its full potential. I know this because I sent pictures AND ran the serial number through this gentleman to get the answers that the original owner refused to answer.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • stangman67
    stangman67 Posts: 2,185
    What in the hell did I miss with this one?
  • Nightfall
    rebelsoul wrote: »
    afterburnt wrote: »
  • daddyjt
    daddyjt Posts: 2,326
    If it was in fact a series II, the back panel would look like this:
    Listen, if you are happy with the amp, then we’re happy for you. Fact is, it’s kind of odd, they way you came here out of the blue to brag about buying a piece of Sunfire gear. The seller left a pretty bitter taste around here, with they way he conducted himself. That’s why you are being met with raised eyebrows.
    @pitdogg2 has done his research, and knows more about your amp than you do. For my part, I was simply trying to warn you that you may have a time-bomb on your hands. Also, it’s worth noting that Sunfire was founded in 1994, so not sure how this guy has been working on Sunfire gear for 30 years. I am very involved in the Carver repair community, and while there are quite a few of us that work on Carver gear, I only know of a small handful (NOT including myself - I know my limitations) that work on Sunfire.
    Best of luck.
    "Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
    ― Aleksandr Solzhenitsyn
    F1nut Posts: 49,799
    stangman67 wrote: »
    A banned member coming back pretending to be someone else and only fooling himself.
  • stangman67
    Cool, that sounds about right for this place lately
  • boston1450
    boston1450 Posts: 7,472
    stangman67 wrote: »
    You didnt miss anything :)
    Randy/Maine
  • vcwatkins
    vcwatkins Posts: 1,993
    rebelsoul wrote: »
    It sounds Amazing!!!! The guy had alot of really nice equipment. Very knowledgeable.
    Smoke free home. I had this same amp about five years ago and had to sell it when I got laid off. This one sounds better then my last one. I had the plastic speaker connects, this one has the gold metal ones.
    My vote for post of the year. Hilarious.
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • ptrooper
    ptrooper Posts: 501
    rebelsoul wrote: »
    The one I bought
    picture of the front panel?
    I have 3 sunfire sig series 2's and none look like this..mine are clear plastic around gold ctr locking hole.
    An early 225 x 5 architects choice series 2 i recently sold had the coloured speaker cable nuts on the rear as to the first pic you posted.
    I have seen an early sunfire 5 x 200 with the gold rear cable nut locks which is identicale to your second pic above!
    nooshinjohn Posts: 25,098
    Sunfire was inconsistent at best on the build of these amps. Bob used whatever he could get for as cheap as possible at times, and binding posts were no exception. I have seen this style binding post used on early Sig models of all types, with the plastic ones used on the entry stuff. If production ran out of the gold ones for the Signature, they would use the lesser posts.
    Bill Flannery is the only guy Bob trusts with these amps, and he is the only one to have all of the factory documentation to keep these amps going. Anybody else would be doing a hack job.
    pitdogg2 Posts: 24,576
    Agree
    Agree100% I talked to Bill for many hours about the OP's amp. He is very passionate about these amps and goes though great length's on many as he is a perfectionist.
  • rebelsoul
    ptrooper wrote: »
    rebelsoul wrote: »
    The one I bought
    that pic was a sig1
  • rebelsoul
    So let me get this right there are a couple of different versions of the sig 1 and 2
  • rebelsoul
    Agree
    Thank you!!! that explains everything. And joe told me about this site
  • ptrooper
    ptrooper Posts: 501
    I personally liked the metal/gold plated as they felt real solid compared to the clear plastic nut etc ,but they could be easily shorted due to them being so close together.
    The signiture series 2's i have are all 240v and all have "clear plastic" nuts with metal/gold plated washer base for speaker cable securing,I would have guessed the clear ones were considered to be better due to them being "exported to Australia".
    Bill Flannery was extremely helpful when i had mine all recapped ,he gave full instructions and sent all the materials for my Tech to install here in Perth,Australia.
    If i asked a question he wasn't sure on ,he would ask Bob and then forward Bob's personal reply.
    Great service !!!These amps go well with the first generation SRS's.
    Agree
