I2S (hdmi) connection
marvda1
just tried this connection tonight between my jay's audio transport and L.K.S. dac and the sound is detailed with a large sound stage and spot on tonality. the notes are airy and come from a pitch black background.
i had been switching between coaxial and bnc to see which sounds best. if you have I2S connections give them a try. i'm just using some generic hdmi cables but will try some wireworld hdmi.
Puritan PSM156
Puritan PSM156
That's what I use with the PSA DSD. I'm using the WW Platinum Starlight and I agree, it's big, detailed and deep. Wish everything had this connection.
I wanted so bad to use the I2S connection between my transport and dac. I was looking to upgraded my cable, but was told they are not compatible.
Unfortunately, there isn’t an I2S standard
Here’s what Brad (at Revelation Audio Labs) relayed to me
"It is not possible since the North Star generates single-ended I2S and the PS Audio needs Differential I2S. Not compatible."
btw Nice score on the LKS . . . What have you compared it to so far?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
I have an Oppo BDP-105 but haven't attempted to use the I2S on my PS Audio Directstream DAC. As stated above...there is no standardized format for I2S. Anyone interested, there is a very long thread (among others) on the PSA site re. this subject and there are devices being successfully employed to do conversions from one manufacturer to another.
https://forum.psaudio.com/t/getting-oppo-dsd-output-to-the-direct-stream-dac/2744/338➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬ -
That's one of the reason I'm looking to have a complete PS system.
Does anyone know if the HDMI audio out from the UPD 205 works with the PSA Perfectwave?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Just thinking that Doug might be someone to reach out to on this. I know my April Audio dac has an I2s output, but, it uses a totally different type of cable than an HDMI. There may be a chance that a special cable can be built to fit a particular piece if the pinout is known.
I2S uses an HDMI 2.0... I have an Oppo 203 with I2S interface upgrade board into my PSA Pre/Dac. I don't think the Oppo HDMI audio is I2S.
The way to test it John would be to see if you can play SACD from the Oppo to the DAC... If you don't hear anything than the answer is no.
http://www.oppomod.com/
But don't be spoofed by a hybrid playing the cd layer.My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Mikey081057 wrote: »I2S uses an HDMI 2.0... I have an Oppo 203 with I2S interface upgrade board into my PSA Pre/Dac. I don't think the Oppo HDMI audio is I2S.
I'm not sure that's a blanket statement. I have other pieces that have I2S and the cable is completely different than HDMI. Not the same number of conductors, and, dimensionally built differently. -
my l.k.s. dac has i2s-h and i2s-e connections, they are different connections.
I am using the i2s-h (hdmi) connection.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
My PSAudio device uses the HDMI std and the oppomod card has jumper options for PSA and another I forget manufacturer... Both will use the HDMI cable.My New Year's resolution is 3840 × 2160
