I2S (hdmi) connection
just tried this connection tonight between my jay's audio transport and L.K.S. dac and the sound is detailed with a large sound stage and spot on tonality. the notes are airy and come from a pitch black background.
i had been switching between coaxial and bnc to see which sounds best. if you have I2S connections give them a try. i'm just using some generic hdmi cables but will try some wireworld hdmi.
Puritan PSM156
  • kharp1
    kharp1 Posts: 3,453
    That's what I use with the PSA DSD. I'm using the WW Platinum Starlight and I agree, it's big, detailed and deep. Wish everything had this connection.
  • GlennDog
    GlennDog Posts: 3,152
    I wanted so bad to use the I2S connection between my transport and dac. I was looking to upgraded my cable, but was told they are not compatible.
    Unfortunately, there isn’t an I2S standard
    Here’s what Brad (at Revelation Audio Labs) relayed to me
    "It is not possible since the North Star generates single-ended I2S and the PS Audio needs Differential I2S. Not compatible."
    btw Nice score on the LKS . . . What have you compared it to so far?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • JayCee
    JayCee Posts: 1,509
    edited September 2019
    I have an Oppo BDP-105 but haven't attempted to use the I2S on my PS Audio Directstream DAC. As stated above...there is no standardized format for I2S. Anyone interested, there is a very long thread (among others) on the PSA site re. this subject and there are devices being successfully employed to do conversions from one manufacturer to another.
    https://forum.psaudio.com/t/getting-oppo-dsd-output-to-the-direct-stream-dac/2744/338
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS, PS Audio AirLens⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • kharp1
    kharp1 Posts: 3,453
    That's one of the reason I'm looking to have a complete PS system.
    nooshinjohn Posts: 25,918
    Does anyone know if the HDMI audio out from the UPD 205 works with the PSA Perfectwave?
  • kharp1
    kharp1 Posts: 3,453
    Just thinking that Doug might be someone to reach out to on this. I know my April Audio dac has an I2s output, but, it uses a totally different type of cable than an HDMI. There may be a chance that a special cable can be built to fit a particular piece if the pinout is known.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I2S uses an HDMI 2.0... I have an Oppo 203 with I2S interface upgrade board into my PSA Pre/Dac. I don't think the Oppo HDMI audio is I2S.
    The way to test it John would be to see if you can play SACD from the Oppo to the DAC... If you don't hear anything than the answer is no. :D
    http://www.oppomod.com/
    But don't be spoofed by a hybrid playing the cd layer.
    Garage | Polk Monitor 5B's
  • kharp1
    kharp1 Posts: 3,453
    I'm not sure that's a blanket statement. I have other pieces that have I2S and the cable is completely different than HDMI. Not the same number of conductors, and, dimensionally built differently.
  • marvda1
    marvda1 Posts: 4,945
    my l.k.s. dac has i2s-h and i2s-e connections, they are different connections.
    I am using the i2s-h (hdmi) connection.
    Puritan PSM156
  • My PSAudio device uses the HDMI std and the oppomod card has jumper options for PSA and another I forget manufacturer... Both will use the HDMI cable.
