I ended up with 2 left SDA SRS 2.3's from craigslist, now what?
Hi Everyone,
I found a mint pair of SRS 2.3's on craigslist brought them home and found out they are both left speakers? Am I screwed or can I still use them and will they still good? I have not hooked a cable between them because I'm concerned it may damage something in my amp or the speakers. Really bummed, I was totally looking forward to enjoying these for years to come. Any advise is appreciated.
John
«134
  • John, not good. Sell the components on the bay.
  • Thanks for the reply, sucks
    pitdogg2 Posts: 27,055
    Sell me the passives
  • Nightfall
    Nightfall Posts: 10,084
    Oof. I'm sorry man.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Yep, not cool....anyone know if I can use these? Are they the same inside and should I use a cable between them?
    edited September 2019
    It will not work correctly for SDA with two of the same sides. As for plain stereo speakers it may work ok but still not ideal. Plugging in the cable the amp may see a direct short and let the magic smoke out.
    nooshinjohn Posts: 25,928
    It would take a serious commitment, but you could make a new front baffle for one of them I suppose... I have zero experience in doing that kind of work, so take that advice with a large grain of salt...
    F1nut Posts: 51,778
    Part them out.
    Why would a new baffle not work Jesse?
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Good idea... or just start scouring the country for the person with 2 right ones! :p
  • So, if I understand you would not use the cable to connect the 2 speakers? But it may be OK, to use them like regular speakers? I was hoping the internals are all the same and it was just the layout of the drivers? This I can live with. But I really wanted to try the SDA Cable
    F1nut Posts: 51,778
    John312 wrote: »
    You'll never obtain a balanced soundstage.
    F1nut Posts: 51,778
    It would....after you destroy the cabinet trying to take it apart.
  • BlueFox
    BlueFox Posts: 15,251
    Did you try to return them?
  • I'm trying to contact the seller now, but no reply, I've been looking for some of these for a while and was very, very excited to try them, This is my first leap into vintage speakers and vintage Polk. I had no idea there was a left and right util I got home. Expensive lesson for sure. Is it safe to hook them to my amp? is it safe to connect a wire between them? I would like try and give a listen.
  • BlueFox wrote: »
    Craigslist has a return policy?
  • Nightfall
    BlueFox wrote: »
    Maybe the seller will be understanding. Probably not but there are good people out there. Maybe he had two pairs in storage and wasn't paying attention either. Maybe he'll refund you. Maybe he knew all along and he'll ignore you. Find out.
    afterburnt wrote: »
  • Flip upside down and hoop a wire between them? Or just run a normal stereo speakers without connecting them together with the SDA cable?
    One of the cabinets would need to be rewired as a right side before trying anything with the SDA, so no. If these are hard to come by in your neighborhood, I would seriously consider reworking one of them to be a right side. If you do not have the skills to do so, a competent cabinet builder should be able to pull it off.
  • I hope the seller is cool, trying to reach him now, but no luck.
  • Thanks everyone for the input. Is it just moving the drivers? Or do I have to worry about the guts, crossovers and all the internal's? I'm worried about damaging the speakers or my amp...last thing I need is smoke and fire
    I would not worry about anything right now until you get the front baffle squared away. You will not be able to get anything that sounds like what they should until the speakers are mirror-imaged. After that, you can rewire the drivers.
    This is going to be a big commitment in time and money to get sorted, but it will be a rewarding experience and be worth it in the end.
  • It's a shame, they are in very, very good condition and I'm embarrassed to say I paid a almost full price. Lets just say far north of $500....crap
    Were you planning on doing any upgrades to them at all? Hopefully the seller will be a stand-up guy and at least give you some of your money back, if not a full refund. Where are you located?
  • I hope so, I asked for a partial refund and got nothing....Crickets
    audioluvr Posts: 5,916
    So let's back up here a second. Are you SURE they are both the same channel? One should have two drivers on the right and one should have two on the left. If that's not the case then John has a point that you could possibly have the opposite channel have two holes filled and two drilled (if done right) The crossovers and internal wiring (albiet on the wrong side) are the same so you shouldn't have magic smoke if you connect an interconnect as long as you are running a common ground amp.
    As for Jesse's comment about imaging symmetry... well, no one knows for sure what the impact would be but there is always that possibility. IF you want to pursue this further there are a few here that could help with proper repair (including Jesse...).
  • Thank you Audioluvr and everyone! And I think I will try the baffle mod. Both speakers are labelled "left" on the rear and both have 2 drivers on the left side. If the internals are the same I will move 2 drivers and fill 2 drivers as suggested. Not sure how to fill them so they look good but I may try. they look so darn good without the grills on.
    F1nut Posts: 51,778
    The cabinets are a monocoque construction. IIRC, the joints interlock, so I don't know one could remove the baffle without destroying the cabinet.
    There's no way they will sound right with the SDA cable in use as is. One thing you could try is swapping the stereo and SDA drivers along with their wires in what would become the right channel. In the 2.3 the SDA drivers are the two in the middle of the row of four. The top and bottom donut drivers are frequency restricted (sub bass) stereo drivers.
    I think if you drill the two holes with a hole saw then use those pieces and the sawdust mixed with wood glue as filler or even an epoxy to reglue it in the holes that would work. Use a greased piece of cardboard or something taped to the inside for backing so your filler piece sits flush.
  • Wow this looks like some work, also is there an easy way to check if my amp is a common ground amp? and is it safe to hook these to any amp without the SDA interconnect hooking then 2 speakers together? I just picked these up today and I'm dying to try them out....Great forum and awesome people on here. Nice job and many thanks everyone!
