Fluance Reference Series Turntables
displayname wrote: »It’s better than nothing, that’s for sure. My main tips would be do your final rinse with distilled water and use a lint free microfiber cloth for the final dry. That should help cut down on the clicks and pops.
Thanks I'll add that to the routine to use Di water. Our water is fairly soft with minimal lime build up. I don't plan on cleaning new records this way but for what it's worth they sound a lot better. The clicks and pops seem to also go away after a few playthroughs on a freshly cleaned record. -
Not sure about the lip. I’d probably need a picture. But it sounds like you got things squared away. It’s good that the TT defaults a little heavy vs a little light.Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
Finally spinning some records now. I give it a thumbs up from first listen, Bottom end has more punch. Mids and highs are crisper and more detailed.
displayname wrote: »Not sure about the lip. I’d probably need a picture. But it sounds like you got things squared away. It’s good that the TT defaults a little heavy vs a little light.
Managed to get a pic. Does this seem normal?
https://imgur.com/a/482EZsk -
I'm sorry -- what are you comparing it to? I don't remember and I am too darned lazy to go back & look? Same cartridge?displayname wrote: »Not sure about the lip. I’d probably need a picture. But it sounds like you got things squared away. It’s good that the TT defaults a little heavy vs a little light.
squared away...
sorry!
That does look to be a little bent upwards. I don’t recall mine looking like that.displayname wrote: »Not sure about the lip. I’d probably need a picture. But it sounds like you got things squared away. It’s good that the TT defaults a little heavy vs a little light.
Discogs -
Compared to Audio Technica ATLP120 with stock cartridge. @mhardy6647
ahh! OK! That's very clarifying. Thanks!
Is there a notable difference between the Red and Blue M2 cartridge? I'm hearing you need Bronze or Black to really get a bump in performance. Would be open to upgrading in the future.
I've never spent significant time with the Red, but I had the Blue for awhile. I've heard from people who are more familiar with the 2M line that many thing the Blue is really the sweetheart of the line as far as bang for the buck goes.
If your Red is in need of a stylus change, then it makes sense to move up to the Blue. If you're looking in the price range of the Bronze or the Black, I'd try to get your ears on them, plus some other stuff. I think there are a lot of really good options in those price ranges, Hana, Grado, Nagaoka, MoFi, etc.
At a certain point, the arm/bearings will be a bigger limiting factor than the cart. It's hard to say what that is exactly. The cart will always make a difference. But there is a point when you're likely not getting everything a cart has to offer without a better arm system.Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
Discogs -
displayname wrote: »Is there a notable difference between the Red and Blue M2 cartridge? I'm hearing you need Bronze or Black to really get a bump in performance. Would be open to upgrading in the future.
Appreciate the insight it is very helpful. Will definitely try the Blue when this one goes out. Also washed the first record today with a distilled water rinse and it sounds very good. Regarding the scale just wedged a thin butter knife underneath and straightened out the platform by pressing down a bit on the front. Didn't want the hassle of returning it. Checked it with the calibration weight and everything is still good. Now to listen to some records! -
Flash sale on the RT80 - 50% off for a few more hours. Use offer code FLASHRT80 at checkout.
https://www.fluance.com/rt80-high-fidelity-vinyl-turntable-record-player-with-premium-cartridge-diamond-needle?utm_source=email&utm_medium=flash-sep-2019&utm_source=Fluance+USA&utm_campaign=8584d9825a-EMAIL_CAMPAIGN_2019_04_26_02_22_COPY_04&utm_medium=email&utm_term=0_d35231bad0-8584d9825a-9351267&mc_cid=8584d9825a&mc_eid=9fd8eb6537 -
Gone already...
Fluance needs to fix their website. I immediately added one to the cart, and then the website came to a crawl. By the time I finally got it to the checkout, the price was back up and the message said the coupon code offer was sold out. Odd though... they still had RT80s for full price. -
Gone already...
sounds to me like their website's working just at they planned
They probably figure some folks either won't notice the "price increase" or they'll just buy it anyway.
mhardy6647 wrote: »Flash sale on the RT80 - 50% off for a few more hours. Use offer code FLASHRT80 at checkout.
Gone already...
Ah... Marketing 101. Or is it Marketing 202?
Internet Marketing 101
Eyeballs on pages.
