SDA SRS Upgrade
2
    VR3 Posts: 29,458
    This is a sda SRS build I did a while back with a back lit face plate
  • xsmi
    xsmi Posts: 1,801
    That's absolutely stunning! Do you just follow the wiring schematic?
    2-channelBelles 22A Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
    VR3 Posts: 29,458
    edited August 2019
    Thank you 😊
    Yes, just be cognizant of ground and where drivers connect
  • xsmi
    xsmi Posts: 1,801
    I'm going to ask a totally stupid question. Does the horizontal Plexiglas piece interfere with the mid-driver passive coupling?
    VR3 Posts: 29,458
    edited August 2019
    No, no issue there
    I do ask, and not that you would, do not copy my design.
    Thank you
  • xsmi
    xsmi Posts: 1,801
    VR3 wrote: »
    Thank you
    Man, I couldn't if I wanted to! :D
  • xsmi
    xsmi Posts: 1,801
    So, what's the going rate to have the old caps/resistors removed and the new ones installed for me? :/
  • JayCee
    JayCee Posts: 1,509
    xsmi wrote: »
    PM Trey. He doesn't conduct business in the forum.
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
    pitdogg2 Posts: 27,126
    edited August 2019
  • xsmi
    xsmi Posts: 1,801
    I know that the part that is circled in blue is the tweeter protection and I know what I need to do with that. However, those small brown parts circled in red, what are those? Do I leave those on the board? Or do I cut those and solder them together as well?
    VR3 Posts: 29,458
    Bypass caps, just remove and leave blank
    750pf mica bypass caps to help the mylar caps sound better. Like Trey said no need to replace when using better polypropylene film caps.
  • xsmi
    xsmi Posts: 1,801
    I've got the boards cleaned off and I am ready to start soldering :s the new caps on, and the leads from the caps are too large to go in the holes on the boards. what do you guys recommend to fix this problem?
    edited October 2019
    clean the old excess solder out of the hole....
    Do @VR3 a favor and please start your own thread on this matter.
  • ChrisD
    ChrisD Posts: 101
    @pitdogg2 This IS xsmi's thread...
    edited October 2019
    ChrisD wrote: »
    I'm sorry I apologise @xsmi I seen Trey's stuff at the top of the page. My phone keyboard has a tendency to cover important stuff like the page numbers (smacks forehead)
    Thanks @ChrisD
    F1nut Posts: 51,859
    xsmi wrote: »
    The holes should be large enough. Try what Ivan suggested. If it's still a problem you can drill out the holes very carefully with the next size up bit.
  • xsmi
    xsmi Posts: 1,801
    ChrisD wrote: »
    Thanks @ChrisD
    No apologies needed, bro.
  • xsmi
    xsmi Posts: 1,801
    edited June 2020
    WOW!! I haven't heard my SDA's in 8 mos. I haven't been able to sort these boards.
  • Gardenstater
    Gardenstater Posts: 4,785
    Oh no!! What issues are ya having? Forgot what goes where? Can you use your before photos as a reference guide?
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • xsmi
    xsmi Posts: 1,801
    Afraid to actually solder to the boards. If I burn these boards, I'm cooked. :D
  • Gardenstater
    edited June 2020
    Make sure you use some solder tip tinner prior to each soldering followed by a wipe with a wet sponge, such as this:
    https://www.amazon.com/MG-Chemicals-SAC305-Container-Formulation/dp/B003BDOEUU/ref=sr_1_5?crid=34Q5IVNCPGG38&dchild=1&keywords=solder+tip+tinner&qid=1593294542&sprefix=solder+tip+,aps,154&sr=8-5
    Also make sure the board is clean with some abrasive pad or fine steel wool and some alcohol. Place the component with leads where you want it and have something like double sided 3M tape and/or a cable tie holding it in place. Apply paste flux with something like a toothpick or a cotton swab to the lead and the board. Make sure your iron is fully hot and touch the solder to the tip, and make sure it melts rapidly and flows onto the tip, tinning it even further. Touch the tip to the component lead and PCB copper at the same time and give it a few secs to heat up, then touch the solder to the opposite side of PCB and lead and it should flow all around and be shiny. Only apply a minimal amt of solder. Pull the tip away and let it cool undisturbed. If it's shiny and even it's probably a good solder joint.
    Practice makes perfect.
    Post edited by Gardenstater on
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
  • xsmi
    xsmi Posts: 1,801
    Thanks.
  • xsmi
    xsmi Posts: 1,801
    Well, I'm finally starting to put these beast back together.
  • xsmi
    xsmi Posts: 1,801
  • xsmi
    xsmi Posts: 1,801
    Finally fired these up last night for the first time in almost two years. I will NEVER try to solder anything ever again! LOL, however, I think these came out OK. When I turned them on last night at 9PM, the right speaker seemed MUCH louder than the left. When I woke up at 6 this morning, the soundstage has opened up a bit and the bass and piano on Miles' Kinda Blue are dead center, with the horns on the right. So, as these season, I think they're going to sound really good. Top end is still pretty harsh, so I know the caps and tweets need to burn in. I'm hoping to get a good 100 hours on them before I start really listening.
  • xsmi
    xsmi Posts: 1,801
    I have a test CD coming in that will have white noise one it. I'm going to have to run the SDA tests. The soundstage is definitely skewing to the right.
  • djreef
    djreef Posts: 71
    Did you figure out what was up?
    DJ
    = 8-->{I>
  • xsmi
    xsmi Posts: 1,801
    The CD has been held up in the mail.
  • Gardenstater
    You can download test signals here and in high rez formats fwiw. If you have another way of playing digital material besides CD you should be good to go, or if not, maybe burn the file onto a CD-R?
    https://www.audiocheck.net/
    George / NJ
    iFi nano iDSD DAC
    iPurifier3
