Fluance Reference Series Turntables
24
    msg Posts: 10,458
    That's Chumlie!
  • scubalab
    scubalab Posts: 3,105
    chumlie wrote: »
    Quick shipping. Mine is in town already. Delivery Monday.
    Yep. Same here. I’m out of town until Monday night, and since I had it delivered to my office, Tuesday it’ll be!
    UPS for me as well. I’m in PA, not far from where it was shipped though.
  • xsmi
    xsmi Posts: 1,804
    That’s one sweet looking turntable.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • chumlie
    chumlie Posts: 8,658
    Kuddos on fast shipping. Delivered. To bad I have to work today.
  • halo
    halo Posts: 5,618
    pawelmwo wrote: »
    The walnut seems to have the same gloss finish. Wonder why they don't offer a matte or dulled surface. I've thought about it and once it's setup you are not really touching the base are you? They give you the gloves to handle it. At the same time you could go about dulling it with some fine grit sand paper just like you would any piece of furniture. But that is a bit extreme on an expensive piece of base.
    The gloves that Fluance included were too small to fit my hands :/ . YMMV.
  • Might be because those Chinese have small hands.
    – Kevin Alfred Strom
    Clipdat Posts: 13,100
    https://www.youtube.com/watch?v=LgTLx93vyrU
  • scubalab
    Had some time scheduled off this afternoon, so I was able to get home and get the new TT set up and running. I’ll post some unboxing and setup photos later. I’m going to hold off on a more detailed review until I’ve had some time to settle in with it. I can say from a first listen, I like the sound. The really good news is the hum/buzz that had been plaguing the phono section and completely boggling my mind is gone!
    Packaging is very well thought out - everything was well protected and arrived in excellent condition. The plinth is absolutely stunning. The walnut finish is beautiful and the gloss is immaculate. I can already tell though, that it’s going to be challenging keeping it free of dust and fingerprints. The platter is very nice and perfectly balanced. Dust cover is typical with a light smoke grey tint. Hinges are sturdy and the spring loading works well. Actually might be a little too tight as it will actually lift the cover from halfway open.
    Came with the white gloves; they’re small, but stretchy and I was able to use them fine. Another nice bonus was the small bubble level that made leveling the table simple with the three adjustable cone shaped feet. They are spring loaded for isolation, but I noticed it didn’t take much for a record to skip.
    The auto-stop is a nice feature. I was a bit scared at first as the platter doesn’t start spinning when you turn the TT on when auto-stop is on. I thought something was wrong at first (didn’t read far enough ahead in the instructions!), but it starts spinning when you move the tone arm from the rest over the platter. It stops spinning the platter about 30 seconds or so after the needle passes the runout grooves.
    The Ortofon 2M Blue is a nice stylus - a bit more revealing than the Rega I was using on the Audio Technica LP-120. The tonearm is decent, but nothing special. It’s similarly noisy (picks up very light taps on the lid) as the Audio Technica.
    All in all, I’m very excited to get some more time on this as it breaks in.
  • scubalab
    Unboxing/setup photos:
  • xsmi
    xsmi Posts: 1,804
    I'm so jealous. But do you know what makes me most jealous? Being able to change the speeds without taking off the belt. Enjoy!!
  • Milito
    Milito Posts: 2,003
    Looks great!
    mhardy6647 Posts: 35,200
    edited August 2019
    scubalab wrote: »
    Had some time scheduled off this afternoon, so I was able to get home and get the new TT set up and running...
    Might not be an isolation issue per se. The 'skipping' behavior might reflect incorrect VTF setting for the cartridge and/or poor match of arm mass & cartridge compliance (i.e., unfortunate resonance of the arm/cartridge/stylus suspension system). You knew that already, though :)
    The auto-stop is a nice feature. I was a bit scared at first as the platter doesn’t start spinning when you turn the TT on when auto-stop is on. I thought something was wrong at first (didn’t read far enough ahead in the instructions!), but it starts spinning when you move the tone arm from the rest over the platter...
    That was the default behavior on the massmarket Japanese turntables for about two decades! :) They used a little microswitch that turned the tt motor on as the arm was swung towards the platter).
    That's a thread or a hair and not a scratch on the platter, I hope! :o
  • Dang, that is a fine looking TT.
  • displayname
    displayname Posts: 1,232
    These constantly look sharp! I had the 2M Blue for awhile, and I enjoyed it while it was in my system. One of the best parts of these tables is the changeable headshell. That makes upgrades or even just changes in sound super easy. Have fun with it!
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    Discogs
  • pawelmwo
    pawelmwo Posts: 137
    Love that walnut finish. Might need to send this back and get that one.
  • halo
    halo Posts: 5,618
    Have to agree with Mark about the skipping issue because I can bang on the audio rack with my fist, right in front of the turntable, and it does not skip.
    That is a very pretty piece of equipment Al! Enjoy!! :)
  • stangman67
    stangman67 Posts: 2,328
    Wow looks great al! Fantastic setup you’ve got there. I’m betting that lounge and blue combo is a good one :)
  • chumlie
    Got mine as far as the dining table. If I get a burst of energy after work I may open it up and assemble.
  • scubalab
    scubalab wrote: »
    As for the isolation issue... I'm pretty sure that was on me! In my haste, I forgot to set the anti-skate prior to dropping the needle on the first record. I'm sure that had a lot to do with it. I'm also planning on getting a cheap VTF scale to more accurately dial that in. I just don't fully trust the markings on the counterweight. Additionally, the VTF for the cart is 1.8 grams, so a minor complaint would be the 1/8 gram markings on the counterweight.
    And, good eye Mark! That is, in fact, a hair on the platter. As diligent as I was to keep it fingerprint and dust free, it's almost impossible to escape the hairs of our shedding white (English Cream) Golden Retriever pup. I noticed it after I posted the pic, and was too lazy to take another and replace it in the post!
  • scubalab
    chumlie wrote: »
    Dang... I was like a kid at Christmas yesterday. I was off work on Monday and most of the day yesterday. It was hard enough knowing it was their Monday and not stopping at the office to pick it up. I actually made a special trip into the office yesterday morning (while out running errands) because I couldn't wait another day!
  • scubalab
    pawelmwo wrote: »
    I'm sure the black is beautiful too, but man, this walnut finish is incredible! Did they get any more back in stock?
  • scubalab
    DSkip wrote: »
    Looks great Al! I'm not sure which one commands more attention - the turntable or that amp.
    Both... my next pursuit will be a nice wider rack, so I can get them both to the top shelf! I am loving the amp Skip - thanks again!
  • scubalab
    scubalab wrote: »
    Clarification - the hum/buzz is not entirely gone, but significantly reduced. All other inputs are dead silent, but the input with the turntable still has a faint hum when nothing is playing and the volume is turned (way) up. Really not noticeable though, since at the levels we listen, you'd really have to struggle to hear it.
    I plan on trying other inputs on the amp, taking the Lounge out of the chain, etc. to see if that resolves it. I'm doubtful though since it was there with other phono pre-amps and integrated amps, but significantly louder/more noticeable.
    I currently have the Fluance connected to the Lounge phono pre with the stock RCA cable. I have the ground wire going from the TT to the lounge, and the second ground wire from the Lounge to the Triode integrated, although since it's just connecting ground, I assume order of connection wouldn't matter...
    edited August 2019
    Try hooking the TT (and ground) directly to the Tridoe's phono stage, taking the Lounge completely out of the equation.
    hum/buzz?!? Don't make me give y'll my clip lead sermon again, 'K?
    https://forum.polkaudio.com/discussion/comment/2360319#Comment_2360319
    F1nut Posts: 51,953
    pawelmwo wrote: »
    Ummm....hell no to the sandpaper. That is not how one obtains a matte or flat sheen unless you want scratch marks all over.
    As for the TT in question here the finish is polyster, which is a tough finish, but will scratch. Because it's a tough finish repairing a scratch becomes more difficult.
  • pawelmwo
    pawelmwo Posts: 137
    edited August 2019
    What I find really weird is the markings on the counter weight and anti skip dials. They don't match. How is one supposed to get 1.8? The counter weight has 3 ticks between 1.5 and 2 and the anti skip has 4. I watched a video where Fluance shows 1.8 being half way on the tracking force. The anti skip was a bit harder to see.
    I tried to match it as best I could and it sounds fine but is there a preferred way to measure this with any tools? Not sure how super accurate this needs to be. It's my first turn table so keep that in mind.
  • scubalab
    pawelmwo wrote: »
    I agree. That was my only complaint - that the counterweight has 1/8 gram markings, so it's impossible to visually dial in 1.8 (or 1-8/10) grams.
    I ordered one of these... cheap enough, and should be more accurate than trusting the markings on the counterweight:
    https://www.amazon.com/gp/product/B07PDQFXBZ/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  • pawelmwo
    pawelmwo Posts: 137
    scubalab wrote: »
    pawelmwo wrote: »
    Yeah it's growing on me. They did but the sale is gone. I'm not about to pay over $100 more for the walnut :)
  • chumlie
    Looking forward to un-boxing mine.
