Replacement tweeter for RTI A3 (RD0690-3 tweeter)
Hi Guys,
I am looking for a replacement tweeter for a used pair of RTI A3's I found on CL. Rather than throwing them out, I want to try fixing them.
Any idea where I can get them from other than the $90 options on eBay?
Cheers,
Jonathan
    pitdogg2 Posts: 27,024
    Did you call Polk CS?
  • Yes, I have. It is $60 plus shipping through Polk. A little expensive if you consider new A3's are $260.
  • ken brydson
    ken brydson Posts: 8,997
    Probably less if you tell them you're a forum member. Guessing $50 with free shipping.
  • K_M
    K_M Posts: 1,632
    I agree, does sound fairly steep. I get that replacement OEM parts usually cost more, but being into DIY, I know what the price of that tweeter minus the "Polk" faceplate is, and it quite a disparity.
  • polrbehr
    polrbehr Posts: 2,842
    edited October 2019
    K_M wrote: »
    So what is the price of that tweeter (without the Polk faceplate)? Can you provide some links to where he can get one (assuming the guy is still around, he only made 2 posts almost 2 months ago...)
    I am not trying to be snarky here, I have a pair of RTi10s that I would not mind having
    one or two replacements for.
  • K_M
    K_M Posts: 1,632
    The issue is removing the face plate, as it is glued in place.
    It can be done technically, but it very tedious separating the 2 glued parts.
    F1nut Posts: 51,736
    How about answering the question, "So what is the price of that tweeter (without the Polk faceplate)? Can you provide some links to where he can get one."
    F1nut Posts: 51,736
    Still waiting.
    F1nut Posts: 51,736
    And still waiting........
  • kharp1
    kharp1 Posts: 3,453
    You have no idea the amount of time involved with researching 207 lol's, give her/him/it time to finish this research of national security proportion. Plus, it may want to keep the hook up pricing to itself, or, the separating of the name plates didn't go as planned and its fingers are stuck together. Just be patient Jesse.
  • gp4jesus
    gp4jesus Posts: 2,017
    Any RTi A series tweeter will work allowing a broader search parameter. I may be able to help. I have several irons in the fire.
    Tony
    *all connected w/Premiere ICs
  • K_M
    K_M Posts: 1,632
    edited March 2020
    https://www.parts-express.com/dayton-audio-nd25fn-4-1-silk-dome-neodymium-tweeter-element-4-ohm--275-053
    (This is actually a Vifa tweeter, just renamed for dayton audio)
    Two guys supposedly tried this tweeter also, but never heard back, how their experience went. The removal of the old one is fairly hard to do and tedious. Installing the new one is relatively easy.
  • gp4jesus
    edited March 2020
    K_M wrote: »
    Interesting... I’ve looked at this very same tweeter as a RDO-690 replacement!
    I think it should fit w/little trouble. Graph is nearly flat and, right now, tough to beat the price. That Vifa detail important as their rep precedes. Thanks for the input :)
    Tony
