Matching Center Channel?
kadrek
kadrek Posts: 33
I have the Polk Monitor 60 Series II speakers: https://amazon.com/Polk-Audio-Monitor-Floorstanding-Speaker/dp/B006QL0XXQ
I've always used them in 2 channel with a HK 3480 but want to start using them as theater speakers, so I need to get a center channel. Is the CS1 or CS10 meant to be used with the monitor 60's? Or is there something else I can get that would look okay and sound decent for less money?
I'll also need to get a 5.1 or similar receiver, any suggestions for under $200? I don't need it to sound great, just better than built in TV speakers.
Thanks!
