Cheap DAC
I picked up an Adcom GTP-600, and I'm moving on to step 2, finding a cheap DAC to connect my computer, and cable box. It needs to have USB and toslink inputs. The cable box does have RCA and coax digital outputs, but I've found using anything other than toslink introduces a nasty ground loop into the system. Does anyone have suggestions in the under $200 range?
PS Audio Stellar Gain Cell DAC/Preamp
Denon DVD 2910
Quad 12L Active Monitors
Marin Logan Dynamo 700W
  • mantis
    mantis Posts: 17,452
    If you can spend a bit more I have a NAD DAC for sale in the Flea Market.
    Dan
  • Irrenhaus
    Irrenhaus Posts: 1,103
    Here
    HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • rooftop59
    rooftop59 Posts: 8,121
    Game Room 5.1.4:
    Bedroom 2.1
  • aiconn
    aiconn Posts: 277
    I picked up the NAD D-1050 from @Mantis. I've tried everything but the USB input, and so far so good.
    Denon DVD 2910
