Making a record storage bin out of 1 sheet of plywood
muncybob
So I found this cool thread at AudioKarma about doing this. This is the way i want to store my records, much easier to flip through them than try to read the splines. I want to plan my cuts to minimize waste as i plan to build several. The situations is, the cabinets cannot be higher than 24" as they will be on casters and underneath a 16' long shuffleboard table. Unless there is a better way to tackle this, I plan to make the cuts as shown but just reducing the back and 2 sides to 24". Is there a better way to go about this?
Yep, my name really is Bob.
@muncybob ????
https://forum.polkaudio.com/discussion/184917/record-storage/p1
I don't see why you couldn't reduce the back and sides. It would be interesting to hear from others.Denon AVR X4200W
Parasound A23 amplifier
LG 65" Ultra HD4k
LG 4kBR - UP970
Denon DVM 4800
Denon DP 3000 turntable
Saec 308sx tonearm w/
Dynavector 10x5 cart
Vincent PHO 701 Phono Preamp
MIT Avt3 Speaker c's
Audio Quest Big Sur ic's
Polk SDA 1C's modded
Polk LSim 707
Polk LSiM706c
Polk RTiA 3's
Polk 80F/X-RT
Polk DSW PRO 440wi sub
Infinity bu2 sub
"The early Klingon gets the Gagh" -
Yep, was fully intending to do one or more of these but didn't know until Friday what my height limitation would be.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
I made a record rack out of an old futon from college years ago...worked out pretty well.
