Making a record storage bin out of 1 sheet of plywood
muncybob
muncybob Posts: 3,280
So I found this cool thread at AudioKarma about doing this. This is the way i want to store my records, much easier to flip through them than try to read the splines. I want to plan my cuts to minimize waste as i plan to build several. The situations is, the cabinets cannot be higher than 24" as they will be on casters and underneath a 16' long shuffleboard table. Unless there is a better way to tackle this, I plan to make the cuts as shown but just reducing the back and 2 sides to 24". Is there a better way to go about this?
Yep, my name really is Bob.
  • Manticore
    Manticore Posts: 408
    @muncybob ????
    https://forum.polkaudio.com/discussion/184917/record-storage/p1
    I don't see why you couldn't reduce the back and sides. It would be interesting to hear from others.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • muncybob
    Yep, was fully intending to do one or more of these but didn't know until Friday what my height limitation would be.
  • kevhed72
    kevhed72 Posts: 5,187
    I made a record rack out of an old futon from college years ago...worked out pretty well.
