Needing some advice ....
I have a Cerwin Vega Sub-150 that I bought used with a bad amp. I am using it with a Dayton SA240 plate amp that I ran the connection wires thru one of the ports to keep it sealed. It sounds good to me but I've never heard it with the original amp. So I'm wondering if I should rework the case to fit the Dayton or have the C-V amp repaired. Is there a noticeable difference between the two? Also, are there any tweaks you would recommend? Thanks
Harman Kardon HK 505
Harman Kardon HT 500
Optonica RP 3636 mkll
Luxman L210
Luxman T240
Luxman PD-289
Audio Technica at12sa
Audio Technica at440mla
Signet tk5ea
Shure M97xE
ADC XLM mkII
Pioneer CT-F9191
Pioneer RT 707
Pioneer DV 563A
JVC XL-V251
Cerwin Vega Sub 150
Polk Monitor 10's
Polk Monitor 7's
Wharfedale w70d
Wharfedale w60d
Wharfedale w40d
Advent Baby II
Answers
