Receiver advice for 705s & 706 (7.1) with 5ch Marantz amp
juice2544
juice2544 Posts: 22
edited July 2019 in Electronics
I'm considering either Yamaha RX A870 100w, PIONEER Elite VSX-LX503 125w or MARANTZ SR5012 100w
Room size: small 10'x12' Surround speakers: 2 Martin Logan Motion 2i & 2 cheap bose cubes (will eventually swap out for 703s)
Also, is there any difference in the SR5012 & 5013 and in A870 & A880?
  • mdaudioguy
    mdaudioguy Posts: 5,164
    Go Yamaha or Marantz. The differences in the models are usually incremental from year to year. Find a comparison online at a site like crutchfield to see any differences, or go to AVS forums for that info.
  • juice2544
    juice2544 Posts: 22
    My other question: is it possible to forgo the amp with A3070 150w and biamp for the fronts, or is that not recommended for some reason?
  • mdaudioguy
    This is often the next question... Forget "biamping" with a receiver - complete gimmick. 3070 is a better receiver and will sound more refined. While it will power those speakers satisfactorily in a small room such as yours, there's no reason not to use the amp. My recommendation for Yamaha Aventage is to go with the 10xx series and use an amp.
  • juice2544
    juice2544 Posts: 22
    mdaudioguy wrote: »
    Just to clarify, I'm primarily using this for 7.1 movies, thus only 2 channels will be driven at once (maybe 3 with the center)? No intention to use Atmos and if I'm trying to save $170, will the A870 not suffice with a 5ch amp? Any extra benefits in the 10xx series I'm not seeing other than an extra 10w?
  • mdaudioguy
    When the Aventage line first came out, it started at 10xx. As time went by, they pushed it down to lower end models. I'm not convinced that the models below 10xx truly have the refined sound of the higher end models, or if they're just slapping the name on them to justify higher prices, but I'm sure they have some improvements over the RX-V line. If you're trying to save money, only you can decide what your limit should be. The A870 should be fine, especially with some help from an amp. What model is your Marantz 5-channel?
  • juice2544
    juice2544 Posts: 22
    edited July 2019
    I'd be getting https://www.accessories4less.com/make-a-store/item/marmm7055/marantz-mm7055-5-ch-x-140-watts-power-amplifier/1.html & was advised to bi-amp the 705s in 4ch of the marantz amp & use the last ch for 706
    Clipdat Posts: 13,098
    edited July 2019
    juice2544 wrote: »
    Who advised you to do that?
  • juice2544
    juice2544 Posts: 22
    maybe I misunderstood him?
    Geoff4rfc wrote: »
    I would not bi-amp from an AVR, waste of time and effort. A 5ch amp would let you bi-amp. You could power three speakers on a 5ch amp. The Center and the mains, using two of the amp channels per main. 150w would be good for the 706
    We were discussing the RX-A3070 150w as a possible option but b/c I'm looking to make this as cheap as possible, would likely go for the $429-$600 range for a receiver https://www.accessories4less.com/make-a-store/category/avreceiver/home-audio/receivers-amps/home-theater-receivers/1.html?home_audio_key[]=Mulit-Channel Preout&home_audio_key[]=100-120 Watts&r=5d36bc70
    I'm still not clear on how it's possible to "bi-amp" from a 5 channel amplifier that uses one power supply/transformer.
  • cfrizz
    cfrizz Posts: 13,415
    I would go for the Marantz you listed, get an amp, but please do not biamp anything. All you are doing is putting more stress on the receiver, if you get a powerful amp, biamping is redundant and unnecessary.
  • Emlyn
    Emlyn Posts: 4,773
    edited July 2019
    In a 10 x 12 room I’d buy a receiver first and see how it works out. Skip the amp and put more money into the receiver and a subwoofer. A 7.1 system may not even be worthwhile and 5.1 is easier to fit in a small room. If you do want an amp later, a two channel amp should be more than enough since all the power of the receiver can then go to center and surrounds which would be run small anyway. A 704 as the center would also be enough for the space. Save some money there too, and the 706 is larger than most realize so it can be difficult to fit in or on AV furniture.
    Post edited by Emlyn on
  • mdaudioguy
    Emlyn wrote: »
    In a 10 x 12 room I’d buy a receiver first and see how it works out. Skip the amp and put more money into the receiver and a subwoofer. A 7.1 system may not even be worthwhile and 5.1 is easier to fit in a small room. If you do want an amp later, a two channel amp should be more than enough since all the power of the receiver can then go to center and surrounds which would be run small anyway. A 704 as the center would also be enough for the space. Save some money there too, and the 706 is larger than most realize so itmcan be difficult to fit in or on AV furniture.
    Yeah... It wasn't until several posts in that it became apparent he didn't actually already own a Marantz 5ch amp. Sometimes helping folks is tough work... I'm tired...
  • mrloren
    mrloren Posts: 2,473
    Hmm Okay
    First thing, do not bi-amp just a waste of time and money.
    Seconded, get a good AVR Yamaha 10XX or Marantz SR60XX
    Third, a good sub is needed SVS or HSU are the ones I've had great experience with.
    Fourth, Need good speaker wire and interconnects (HDMI-RCA)
    Once setup you may find no need for an amp. If you do then the Marantz is a good one OutlawAudio or Emotiva are also good budget choices
    I'd also say a good 5.1.2 Atmos setup in a room tat size would be better than trying to squeeze in a 7.1. When my oldest moves out next year I keep telling the wife I want to make her room into my man cave and use the bedroom setup.
  • rburgess714
    rburgess714 Posts: 618
    edited July 2019
    I don’t think anyone noted that the Aventage 870 doesn’t have preouts other than sub. You need to move up to the 10XX or beyond.
    Sorry I am wrong the 860 does not but 870 does.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • cfrizz
    The most important improvement he will get by getting an amp is that how much more clearly all the details of dialog/music will become. It is for that reason I always encourage people to get an amp, because receivers usually just don't have the capacity to accomplish this.
  • WLDock
    WLDock Posts: 3,073
    edited July 2019
    juice2544 wrote: »
    juice2544 wrote: »
    So you have $800 for and amp and $400-$600 for an AVR to spend? About $1400 total? Your room is 10'x12'? with no plans for ATMOS? Then consider going 5.1 and get a nice AVR.
    Consider the NAD T 758 V3
    https://nadelectronics.com/product/t-758-v3-av-surround-sound-receiver/
    https://www.ebay.com/sch/i.html?_from=R40&_nkw=NAD+T+758+V3&_sacat=0&LH_TitleDesc=0&_sop=15
    You can read the feedback on the web from those like the DIRAC Live room correction and overall sound quality of the NAD over some Marantz, Denon units with Audyssey or Anthem units with ARC room correction. Plus it has nice high current amps and BluOS Streaming built in. This unit might be able to drive your small room just fine.
    NAD’s Modular Design Construction makes V3 of the T758 a special occasion as one of the small but growing number of surround products with Dirac. Putting aside the aforementioned challenges with learning to use it, it's an empowering tool for the questing audio tweaker who wants the flexibility to experiment with room correction parameters. Coupled here with this fine-sounding receiver, the audible results are beautiful.
    Read more at https://www.soundandvision.com/content/nad-t758-v3-av-receiver-review-page-2#TWK7lz0jql5v8gAw.99
    There is little to say against the NAD T 758 V3. At $1300, it sits in a hugely-competitive price segment for AV receivers and frankly, all I need to hear is Dirac Live and I’m done. It may not have a ton of features but it absolutely has the ones that count – clean sound that plays loud without distortion, Dolby Atmos, Ultra HD passthrough, and the best room correction I’ve heard to date. One might wish for more amp channels or DTS:X but honestly, at this price, I defy anyone to show me a better-sounding receiver.
    https://hometheaterhifi.com/reviews/speaker/surround-sound-speaker-systems-reviews/nad-t-758-v3-av-surround-sound-receiver-review/
    If you find that you do need more power, find a low cost quality used 2, 3, 5 channel amp like this to drive just the mains, or just the front three, or all five.
    https://www.ebay.com/itm/Parasound-HCA-1205A-5-Channel-140-watts-Amplifier/183877919639?epid=66783576&hash=item2acffa6397:g:MLEAAOSwxM1dJtiV
    https://www.usaudiomart.com/details/649536991-bamp-k-st2140/
    https://www.usaudiomart.com/details/649526324-bampk-7250-series-ii-5-channel-amp/
    Post edited by WLDock on
  • WLDock
    WLDock Posts: 3,073
    Also, the LSiM 704c center is on sale for $199! More saving as this speaker will work out fine in your smaller space.
    https://www.adorama.com/pkalsim704c.html?sdtid=13254295&emailprice=t&utm_medium=Affiliate&utm_source=rflaid62905
  • mrloren
    WLDock wrote: »
    Darn great price for that speaker
  • juice2544
    juice2544 Posts: 22
    edited July 2019
    To clarify, I have 2 705s, 706, 2 Martin Logan 2i Freemotion & 2 bose cubes with the sub that comes with the Acoustimass 6 (bose components will be replaced in the future of course but 7.1 is my setup, if I use Atmos in the future, would that be through zone 2?). My room isn't enclosed & it might even go into a large living room without wall constraints. I'm considering the 5ch Marantz amp b/c it comes with a 3yr warranty (dont want used equip.) & my only question to those who are willing to take a closer look is what the minor differences in these are (apart from wattage, that would be worth the extra cost?):
    https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-a870_u/index.html $430 100w
    https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-a880_u/index.html $550 100w
    https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-a1070_u/index.html $600 110w
    https://www.us.marantz.com/us/products/pages/ProductDetails.aspx?CatId=AVReceivers&ProductId=SR5012 $480 100w
    https://www.us.marantz.com/us/products/pages/productdetails.aspx?catid=avreceivers&subcatid=0&productid=sr5013 $570 100w
    https://www.us.marantz.com/us/products/pages/ProductDetails.aspx?CatId=AVReceivers&ProductId=SR6012 $650 110w (not really considering but wondering why MrLoren recommended it)
    I do have an old 1080p RX-A700 w/preouts that I could hook the amp to once purchased & see how the speakers sound w/actual power.
    Post edited by juice2544 on
  • juice2544
    juice2544 Posts: 22
    edited July 2019
    Also, another consideration would be that 8k movies might become available in a couple years meaning the receiver will have to be replaced again.
  • BlueFox
    BlueFox Posts: 15,250
    So?
  • juice2544
    juice2544 Posts: 22
    edited July 2019
    Makes me want to go with a cheaper option, either A870, SR5012 or A1070 depending on if there's a difference in internal parts quality
  • BlueFox
    The receiver just passes the video signal through it to the TV. That is how my Onkyo preamp handles 4K, and I assume 8K will be the same.
  • juice2544
    juice2544 Posts: 22
    I noticed Yamha doesn't have Dolby ProLogic Ilz, can someone elaborate on Auro 3D, Audyssey DSX in the Marantz?
  • mdaudioguy
    The best place to go for learning about that stuff (receiver features and differences) is AVS forums. Not trying to run you off, just saying. A lot of us have accounts over there, too.
  • joecoulson
    joecoulson Posts: 4,943
    Just stay away from Audiogon, full O trolls
  • juice2544
    juice2544 Posts: 22
    mdaudioguy wrote: »
    Funny, I was just browsing there. Having HDCP 2.2 over 2.3 won't cause me any issues I'm guessing?
  • mrloren
    Why the Marantz SR60XX? It's a better receiver than the SR50XX. Just as a Yamaha 10XX it better than the 8XX.
    Look at the weights of these AVR the SR60XX is about 6lb more than the SR50XX, A lot of that weight is power supply.
    All of these receivers come with calibration software built in. I know in the Marantz Audyssey XT is not as nice as Audyssey XT32 that comes in the SR60XX.
    The SR60XX is a 9.2 while the SR50XX is a 7.1. Those two extra channels can be used for a zone 2 setup
    ATMOS/DTSX and Aruo 3D are 3D sound fields. Several ways to hook these up, in-ceiling speaker, bounce speakers (kind of suck) and elevation speakers. This does add to the overall home theater experience.
  • juice2544
    juice2544 Posts: 22
    edited July 2019
    anyone know if Ac4L runs holiday specials?
  • Geoff4rfc
    Geoff4rfc Posts: 2,882
    edited July 2019
    juice2544 wrote: »
    I know they are good folks over there, at least I haven't had a bad experience in the last three receivers I've purchased over. And yes, you're buying refurbished products but you have the option of purchasing an extended warranty, four choices I believe, I always get the max. And, after getting two integras and one Marantz, all three showed up looking and behaving brand new. My DTR-70.4 was a beast of an AVR and showing no signs of wear after nearly 5 years of use when I switched to my pre-processor. It's going to make a great second set up one day :)
    Anyway (oops) my point, give them a call, it doesn't hurt to ask if there is going to be price decrease anytime soon.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
