BBQ Smoker problems
2
    pitdogg2 Posts: 27,153
    Come on Marvin they're 20 ways to BBQ a chicken and they are all right by those who cook them. Let's not spiral this thread down.
    I cooked two slabs of ribs one on my propane grill and one in my smoker. Yes they both had wood smoked the same amount of time. The propane grill I used only one burner from the five it had and the ribs were on the opposite side of the flame both kept at 225 degrees. My guest could not tell a difference in the taste. I actually was surprised they turned out as good as they did. I did this because I wanted an unbiased opinion from my guest as I knew mine would be a very biased opinion. I just wanted to see IF it could be done or IF I would ruin a good slab of ribs.
    Yes prefer the smoker and have not smoked on my grill since.
    txcoastal1 Posts: 13,514
    You know Ivan blind testing does not work ;)
  • Jstas
    Jstas Posts: 14,990
    edited July 2019
    marvda1 wrote: »
    answer this then, backyard propane grillers have no problem with this so called residue. since you know so much about competition smoking it's a fact if judges detect any type of lighter fluid or chemical taste they will judge it low.
    and since you watch so much tv on smoking, the winningest smoker of all time, miron mixon uses lighter fluid to light his smokers whereas other top cooks will not because of the taste.
    since you say it will take so much heat to get rid of the propane residue, how hot do you think that torch is burning at.
    Yeah, ok.
    Propane burns at 3,623 degrees Fahrenheit. That's if it has an ideal air to fuel mixture.
    The torches that you are referring to are ones like these:
    https://www.harborfreight.com/propane-torch-with-push-button-igniter-91037.html
    Or these:
    https://www.harborfreight.com/electric-start-propane-torch-91061.html
    Which are designed with burners to offer the proper A/F mixture for a complete and hot burn of the propane fuel. Mainly because they are intended as tools, not BBQ/Grilling heat sources. They aren't regulated in the same way and it's hard to control heat at low levels with them because of that.
    A burner like this:
    https://www.amazon.com/GasOne-50250-2109-Cast-Iron-Regulator/dp/B0719PVZP1/ref=asc_df_B0719PVZP1/?tag=hyprod-20&linkCode=df0&hvadid=198091107028&hvpos=1o1&hvnetw=g&hvrand=5847351251348348922&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9003790&hvtargid=pla-351310155755&psc=1
    Which is typically found in your average propane based smoker is designed to meter the output by restricting fuel flow through a regulator that matches the amount of air available to the burner to create a heat source. That pressure regulator is critical to maintaining heat levels in the smoker. It needs to meter the fuel to the air supply perfectly. If it doesn't meter enough fuel, it can burn lean and too hot and damage the burner creating an unsafe condition. If it burns way too lean, it can extinguish the flame and vent propane into the smoking chamber turning it, basically, into a bomb. If it burns too rich, you will not get a complete burn and you will get unburned fuel and soot which is not a good taste to put in your face.
    That flame is roughly 3200-3600 degrees no matter how big it is. The difference between a plumbing torch or a utility heating torch is BTUs and there's WAY more of those coming out of a torch than there is a smoker burner. So a propane utility torch putting out maybe 20K BTUs is going to be vastly hotter in a small area like a smoker firebox than the 3000-4000 BTUs, maybe 9000 for the one I linked to. That matters because a single burner propane source is never going to get my smoker over 200 degrees because of the amount of steel and airspace that burner has to heat up to reach that. The propane utility torch could. Hell, it could heat half your house if you were psychotic. But both burn at the same temps but the BTUs determine how much heat transfer those two torches burning at the same temp can heat. A 9000 BTU torch can only heat half the space of the 20K BTU torch and it takes longer to do it because it doesn't have a high enough heat transfer rate. Add to that the fact that there is so much mass from material, food and air in your average smoker that the 9000 BTU burner will never overcome the heat flux of just the air in the cooking chamber before the surrounding air can transfer the transferred heat away from the cooking chamber. It gets exponentially more difficult for the small propane burner when you factor in the heat coefficient of the steel surrounding the air mass.
    In other words, the torches they use to start a wood/charcoal fire are NOT the same as the burners in the propane fueled smokers. If you're gonna rock a propane fueled smoker, make sure you have a quality burner and regulator or it's going to affect your end product. That's just fact. If you want to use a propane torch to burn out your smoker's seasoning, go ahead but make sure it's thick steel or that torch is gonna warp it and it won't seal right. If you want to use a torch to start your charcoal fire, then go ahead, it's easy to do and quick but I'd honestly rather err on the side of caution and use some kindling or wood shavings coated in beeswax. I won't ever use lighter fluid in the smoker.
    I know exactly how judges judge BBQ. I'm not enamored by competition like some folks seem to be, including you. Can you learn something by watching competitions, listening to competitors and actually competing? You sure can! Does that mean that it's your only source? Certainly not! If it is then you're unnecessarily hindering yourself and you should be more open-minded.
    My experience here doesn't come from regurgitating what some celebrity competitor says on a class, book or TV show. That doesn't mean I haven't or won't take their advice into consideration. My experience comes from actually doing this. For a long time, too. About 20 years now and my father did it for most of my youth that I can remember. He still does it too and reluctantly admits that I'm better at some stuff than he is. But I'm better at it because of what he taught me, not in spite of it. He should be proud because I wouldn't be able to knock peoples socks off with a hunk of brisket or a perfectly done pork tenderloin without him.
    You can keep going with your butthurt hissy fit and throw out all the challenges you want, I'll keep knocking them down and you can keep crying about how I've offended your sensibilities and rationalization over your purchase.
    Or you can accept that your setup works for you and you like it and not worry about what I have to say.
    But unlike many other bloviating jackasses on the internet, my stance and advice is coming from me and my experience. Nowhere else. It's honest and real and even if I give someone a hard time about their choice of equipment I will still gather all of my experience and know-how to help them fix whatever problem they have from poor equipment performance to an experienced opinion on recipes and fuels that affect flavors in positive or negative manners.
    However, I know I don't have to worry about helping you because you took a general comment meant in jest that may not have come off as intended over text on a forum and have run with it calling me an egotistical, arrogant idiot instead of blowing it off as a throwaway comment and having an actual, decent conversation. Whether you're right or wrong about that, I can sleep well knowing that I won't be missing a request for help from you because you've already passed judgement. All because you can't get over yourself and the fact that there might be someone out there with as much or more experience than you that has a different opinion. I'll remember not to invite you to my next BBQ, wouldn't want to upset you any.
    Have nice day, sport and happy smoking!
    Expert Moron Extraordinaire
    gudnoyez Posts: 8,169
    I have attended many a rib fest where smokers like yours are used and most of the guys use use oven spray, or other arasol grill grate cleaners, with some elbow grease, or soaks them in dawn liquid detergent and scrubs them. just remember caked on maranaites and BBQ sauces can also add to your flavor which isn't good most guys will tell you to do a through cleaning a couple of times during the season, or more times if you use them on a almost daily basis.
    I don't think anyone was questioning your smoking abilities just your 17 step method which could be overkill in someone else's opinion. Multiple caked on sauces and marinades that have sat on unused grates for a few weeks is just as bad as mold, everyone has different takes on the subject.
  • Jstas
    Jstas Posts: 14,990
    gudnoyez wrote: »
    This isn't about cleaning out the smoker after use.
    This was about a mold problem which typically doesn't happen for people who use their smokers on a more regular basis than a backyard BBQ'er.
    You need heat and lots of it to make sure you sterilize your cooking apparatus after an infection like that. Just like with the BTUs of propane burners, you need a bunch of wood to create enough heat for a long enough period of time to kill anything that's growing.
    However, every step is absolutely necessary. You cannot season nor can you cook on rust. You absolutely need to remove it. You absolutely need to sterilize your cooking apparatus after you clean it. This is about food safety, not ease of doing it. The method I've detailed here takes no risks in possibly ruining your cooking equipment and it doesn't have any compounds that could cause bad tasting food or make someone sick. That's why I detailed this and if someone cares enough about it to take the time to not use any chemicals or accelerators in cleaning or fueling a smoker then this is going to preserve that effort.
    Just because some don't/can't appreciate it doesn't mean it's excessive, overkill or has no redeeming value.
    You can use harsh chemicals, solvents and cleaners if you like but, despite everyone else's anecdotal evidence that someone else does it so it's fine, you're just taking a risk for the sake of time. That's not a slight against anyone, that's a reality.
    You want to clean your smoker out and strip all your hard-earned seasoning just to clean it? Fine by me. It's your end product that will suffer, not mine. I clean my grates all the time, BTW. Between every session. I don't clean the smoking chamber, though, because that seasoning is important to prevent it from rusting and aid in heat retention. The grates have little to do with imparting flavors. They intentionally have a small contact area because you want the food suspended in the smoke as much as possible. They are often coated with some compound or ceramic so that they are easy to clean and less likely to create bad tastes in the process. So clean them all you want. I personally use hot water and a scrub brush, dish soap sparingly with great success. If they are real bad, I'll start a fire in the BBQ grill and BBQ my smoker grates to burn the caked junk off them and then clean them with a scrub brush and hot water.
    I never would have posted about that.
    I posted about this because it's a unique problem that I know how to fix well, someone might have run it to it so I wanted to share what I did and I chose to try and add some levity and humor to it which has not gone over well. Now I have people with no experience telling me I should calm down and then try to educate me while telling me no one was questioning my experience yet, y'all are and telling me I'm an egotistical, arrogant idiot 'cause I wanted to share something useful and tried to make some stupid jokes about.
  • cfrizz
    cfrizz Posts: 13,415
    "It probably won't apply to you Green Egg evangelists and your fake smokers so y'all can go back to arguing about everything else.
    Some of you cheaters with your pellet grills/smokers might run in to this, though. Unfortunately, you'll have to find another way to fix this because your pellet cheater there will be ruined by how I fixed this."
    Sorry John, if you had put a smiley, a wink, or something to indicate that you were joking, this thread wouldn't have gone down the drain. No one can tell when someone is making a joke or being insulting when you are just reading words on a screen. So all that's left to go on is the tone of the words and the actual words themselves. Your words came across condescending and insulting to some and they called you on it.
    Maybe next time try rereading what you have written before hitting post comment.
    BBQ is all good no matter how you cook it!
    EndersShadow Posts: 17,713
    edited July 2019
    Just cover it in Sweet Baby Rays or Open Pit :D....
    I mean it all tastes the same anyway :p;)>:)
  • kharp1
    kharp1 Posts: 3,453
    Well, now, I guess I'll walk back my "stupid" comment since you posted some other pretty smart stuff. But, you have to realize you cross a Mason-Dixon kind of line when you start calling out non-traditional kind of smokers. I'd rather you just talk about my kin folk. :)
  • Willow
    Willow Posts: 11,239
    Viking64 wrote: »
    lightman1 wrote: »
    Fine! But can it cook hot dogs?
    Yes. If you stand too close to it.
    It would then be called a cocktail wiener, no?
  • cmy330go
    cmy330go Posts: 2,341
    All you idiots with your cheater cookers can go pound sand. This is how the non namby pambies cook. Shameful that you even call yourselves men.lisl5anq0ag1.jpg
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • Jstas
    Jstas Posts: 14,990
    cmy330go wrote: »
    You mean like this?
    Y'all done with your butthurt yet?
  • kharp1
    kharp1 Posts: 3,453
    I still have a fire pit that I throw wood in and get primal with. I've had side box grills and everything has its time and place, however, I've found having control of your elements is critical to getting a good, proper smoke. Enter the electric cabinet smoker. I can get pinpoint temp and unlimited control over smoke.
  • marvda1
    marvda1 Posts: 4,954
    you take the fun and challenge out of it :D
    Puritan PSM156
    marvda1 wrote: »
    Or save yourself from murdering a $40 brisket and killing 10hrs of your time
    Viking64 Posts: 7,583
  • cfrizz
    txcoastal1 wrote: »
    marvda1 wrote: »
    :o Ouch, that must hurt! How long does it take you to get over that.
    cfrizz wrote: »
    txcoastal1 wrote: »
    marvda1 wrote: »
    About 12beers...it's not just about the money/time, it's that look your wife gives you when she would have rather you taken her dinner :/
    txcoastal1 wrote: »
    cfrizz wrote: »
    txcoastal1 wrote: »
    marvda1 wrote: »
    So the beers are for the wife then.....
    :p
  • seeclear
    seeclear Posts: 1,244
    I do think mine is the Brinkman that you mentioned. I dont see it on the Home Depot website anymore, I guess that's not surprising if they are out of business. Being in Colorado, we dont have the mold problem here, so hopefully I never have to deal with this.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • hochpt21
    hochpt21 Posts: 5,423
    Just put the order in for a Weber Smokey Mountain 18 and a BBQ controller fan. Really looking forward to it.
  • delkal
    delkal Posts: 764
    edited July 2019
    marvda1 wrote: »
    take a look at this. they have a larger one coming out but it will be $700.
    https://www.oklahomajoes.com/bronco-drum-smoker?msclkid=786abe0029d4153bfb01e3345d2b626d&utm_source=bing&utm_medium=cpc&utm_campaign=Brand-Bronco&utm_term=oklahoma joe's bronco smoker&utm_content=Bronco-General
    the problem he talks about (intake tube) on the youtube video, ok joe will send you a free replacement one. you might be able to order a second cooking rack so you can have two later cooking for more capacity.
    https://www.youtube.com/watch?v=9cK8uON0I2c
    Stop posting stuff like this! You just made me spend another $250!
    After looking at your post I did some research and long story short.....I am seasoning a new one in the back yard as we speak. They have them on sale at walmart for $247. So far I am extremely impressed by its thick steel and overall weight (150 lbs). The temperature has been stable and you can increase it or decrease it by adjusting the dampers.
    Mine also has the slight intake tube misfit but the video really blows this out of proportion. The fire needs air and the small amount that might be leaking in is insignificant. Just close the intake damper a little more. Or just shim it on the inside with a few layers of aluminum foil.
  • marvda1
    edited July 2019
    they will send you a free new one.
    I would also see how much a second cooking grate would cost so you have double capacity.
    Puritan PSM156
  • delkal
    delkal Posts: 764
    I did hear they will send you a replacement intake for free but will have to experiment with the smoker some before I decide to complain.
    The one grill they do give you is kind of small. They show a picture of it with two hams on it but eyeing it up they must have used the worlds smallest pig. I think a second rack is about $20 but the grill on my Weber fits if you center it. Its close but just a little small. I mostly want to experiment in hanging the meat from the hooks. It seems like you can load it up that way.
  • BlueFox
    BlueFox Posts: 15,250
    Let’s get back to the original post of needing beaucoup steps to clean a grill. :)
  • delkal
    delkal Posts: 764
    edited July 2019
    OK..............There is a fine line between prized seasoning and crud. Seasoning should be like a a thick black lacquer that is waterproof. You can run your finger on it and just get a slight brown mark. No Black goo with chunks.
    If your grill has enough crap on it to mold its crud. Clean it more often. Hose everything off occasionally and hit it with a wire brush. You will not remove the seasoning. Just the rancid grease and chunks of spoiling meat.
  • polrbehr
    polrbehr Posts: 2,842
    So I cleaned my smoker a few days ago and decided to do a few ribs today. The results as follows may or may not have anything to do with a freshly cleaned/seasoned smoker, but I’m leaning towards — may! :)
  • krazypolk
    krazypolk Posts: 745
    polrbehr wrote: »
    What sauce did you finish them off with?
  • kharp1
    kharp1 Posts: 3,453
    Those look GREAT!!! I'm hungry!
  • polrbehr
    edited August 2019
    There is actually not much on the rack at all, maybe a Tbsp spread around, even less on the individual ribs. The sauce is my own, modified from a recipe I got online a few years ago, and I drizzled a little honey and a few shakes of brown sugar at the start of the last hour in the smoker as well (never tried that before, good results though)
  • krazypolk
    edited August 2019
    polrbehr wrote: »
    Right on, good to hear it wasn't some generic off the shelf stuff.
    They look great.
