New pre-amp has three RCA inputs, need four
I've been thinking about upgrading my 25yo solid state preamp with a new tube pre-amp. I'm still looking, but as I compared specs, I noticed that quite a few new pre-amps (in the price range I can afford) had a limited number of RCA inputs, often with a couple of XLR inputs as well. (I don't have any equipment that uses XLR at the moment.)
This brings up a question that I'm eager to answer: what do you do when you need more RCA inputs than the pre-amp has?
I figure a few of you have probably encountered this problem, so please let me know how you handled it, and thanks!
Bob
  • SIHAB
    SIHAB Posts: 5,427
    edited July 2019
    Hi Bob, is used an option? Remote?
    True XLR are nice to have if ever...
    Oh, and you could always get an XLR to RCA cable.
  • marvda1
    marvda1 Posts: 4,943
    or an xlr to rca adapter.
    Puritan PSM156
  • Wardsweb
    Wardsweb Posts: 942
    I built this little switching box for a friend. It uses an Elma switch 04-1261. The 04-1264 is the same with gold contacts. The steel bar is just for added weight to keep the box from moving around, when you are switching it.
  • SIHAB wrote: »
    I currently have a used pre-amp and amp (Conrad Johnson SS's). I think this time it's going to be new, just to savor the 'newest' of it all.
  • marvda1 wrote: »
    I have seen these: anyone have preferences for brand?
  • Wardsweb wrote: »
    Very cool, and indeed an option I have thought about. I really like enclosure (not that the rest isn't nice too). The only reason not to go this route is YAB: Yet Another Box. LOL. I'm space-limited.
  • SIHAB
    SIHAB Posts: 5,427
    I've been kicking around making a passive pre...
    Would be a fun project!
  • erniejade
    erniejade Posts: 6,321
    I use a Shciit sys. It is passive and outside of adding another set of RCA cables, I cannot hear the difference going though it and not going through it.
  • SIHAB
    SIHAB Posts: 5,427
    that is why I haven't made my own passive pre.
    Neutral and $49 is hard to beat.
    erniejade wrote: »
    mhardy6647 Posts: 35,000
    edited July 2019
    Luther's solution is nice, but if you're not in the mood to DIY and/or invest in a high-zoot switch box...
    An inexpensive source selector switch is... an inexpensive solution.
    For the price, you can try one, and -- if you find it too degrading of a signal put through it (relative to mainlining the same source into a preamp input), just sell it, karma it, or pitch it.
    They're readily available from the usual suspects :)
    Here's one that's actually fairly expensive and overkill (as an A/V switch, it has three analog channels, L/R/V per source):
    https://www.parts-express.com/parts-express-s-video-audio-and-composite-video-selector-switch-5-in-2-out--180-938
    EDIT: Here's a more... modest option, from the erstwhile MCM Electronics fine family of products :) (now part of Newark):
    https://www.newark.com/mcm/50-6175/switch-box-four-input-source/dp/39C0728?st=audio switch box
    FWIW, I use one of these (the black AZDEN box -- the silver box is a 'passive preamp' with a TVC and a three-source input selector, too), but they're not particularly easy to find on any given day.
    24678440802_27114f1d77_h.jpg009 by Mark Hardy, on Flickr
    A similar but somewhat more sophisticated (but also still completely passive) product was offered by dBx -- these are meant primarily for input and output control/dubbing for recording (analog tape recording :) ) but, I think, can be repurposed as source selectors. They're cheap and plentiful -- I bought one for ca. $25 on eBAY a few years back.
    Ol' Radio Shack (bless their hearts) were the go-to for stuff like analog switch boxes in olden times... heck, they might even still offer one nowadays on their website -- who knows? ;)
    edited July 2019
    R/S A/V switchbox from the early 21st Century :)
    I actually have one of these, too :p ; used it for quite a while prior to getting that Azden gizmo.
    source: http://www.radioshackcatalogs.com/html/2003-04/h009.html
    Despite what the catalog copy says, the one here, at least, is just a source selector -- no RF modulator on board :p
    tonyb Posts: 33,072
    Can I ask, what 4 devices you plan on hooking up to a pre amp ?
  • tonyb wrote: »
    turntable, tuner, cd player, and television (DVD player and Roku on it)
    No cassette deck? No eight track?
    (actually, and in all seriousness, I do still have a cassette deck - dual well! - hooked up to the big-boy hifi upstairs. Just in case, you know?)
    (older photo -- but you get the idea ;) )
    oh, on topic -- there's always the nuclear option when it comes to source selectors... it will require adapting some of one's patch cords interconnects and/or speaker wires cables to 1/4 inch "phone plugs", but that's a small price to pay for flexibility, right? ;)
    24770045716_11ec7d3c13_h.jpg011 by Mark Hardy, on Flickr
    24770042506_c3d355ea2c_h.jpg014 by Mark Hardy, on Flickr
  • ^^^^Wow! Maybe a bit overkill, but wow.^^^^
    For now, I think the best choice will be to buy a couple of RCA to XLR plugs. I've heard good things about the Cardas ones. As I have time to consider my options, I'll continue to think about alternatives and welcome any further opinions you folk may wish to offer. Thanks for your input.
    a bit, yeah ;)
    They're not hard to find, nor particularly expensive.
    Switchcraft also made some less Baroque switchboxes which may be cheaper if one can find one. Heck, maybe they still do?
    The old "audio comparators" much beloved of 1970s hifi stores are expensive (but quite cool).
  • delkal
    delkal Posts: 764
    edited July 2019
    Sometimes if you have an option to use RCA or balanced connections it is an ether/or thing. You can't select between both. Don't just go by the number of inputs in back, its number of outputs that matter. So look up the specs and make sure you can select them all independently.
    ^^^ good point. I was wonderin' whether one input position might be either balanced or unbalanced.
  • delkal
    delkal Posts: 764
    edited July 2019
    That is usually how it is. No idea what would happen if you plugged two different inputs in both (and I wouldn't want to try)
    delkal wrote: »
    Like crossing the streams in Ghostbusters.
  • dhart86
    dhart86 Posts: 1,594
    If you are looking to replace your pre and your amp. This may be perfect for your needs:
    https://forum.polkaudio.com/discussion/187017/belles-250i-integrated-amplifier-w-tubed-preamp-section-ss-power#latest
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • kharp1
    kharp1 Posts: 3,453
    For the money might be pretty hard to beat.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,767
    The best suggestion was above ^^^^ by erniejade - For $49
    SYS stands for "switch your, er...schtuff." Sys is a simple, 2-input passive preamp. No electronics. No power. No distortion. Just a 2-way switch and a potentiometer.
    https://www.schiit.com/products/sys
    Harry / Marietta GA
    edited July 2019
    sans potentiometer is probably better for an input selector. I doubt that the attenuator in the Schiit Sys provides a constant impedance.
    Nothing (including the cheap switchboxes I myself recommended earlier in this thread) adds no distortion when patched into the signal chain. That Schiit thing is fine as a "passive preamp" but is probably too complicated (i.e., having an attenuator on board) for its own good just to add an additional line level, unbalanced source input (IMO, IME, YMMV, et cetera, et cetera, et cetera). :|
