Looking for insulated banana plugs
muncybob
Currently have spades on amp and speakers. Seem to have a hard time keeping them tight and the other day they touched each other on one speaker and result was a blown tube(could have been worse!). So I'm going back to nanners and to be on the safe side maybe they should be insulated? Locking screws for wire connection preferable to solder.
Yep, my name really is Bob.
... the other day they touched each other on one speaker and result was a blown tube(could have been worse!)...
That is very odd -- vacuum tube audio amplifiers don't usually mind short circuits. -
The amp's(ss) protection circuit kicked in. The tube was in the pre....not sure if that's unusual or not.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
That seems even odder -- although I do have a terrible head cold and I am not thinking clearly.
I like the AQ SureGrip bananas.
Nice tight fits.... If it ain't tight it ain't worth a ____My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I love these
https://douglasconnection.com/product/furutech-fp-202-g-banana-connectors/
10% discount for Polkies too ;^ )2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
When I tighten spades to a post I don't just screw down the post. I start that way but when it seems tight I then wiggle the spade (there is always some play), back it off a bit and tighten the last time by moving the spade AND the post screw together. You can get it a lot tighter. Just be careful......don't overtighten it and break something.
Or how about electrical tape? -
mhardy6647 wrote: »That seems even odder -- although I do have a terrible head cold and I am not thinking clearly.
As is often said, pics or it didn;t happen,Yep, my name really is Bob.
Oh, I believe it happened -- I just cannot fathom why.
Better than a blown speaker.2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones
