Looking for insulated banana plugs
Currently have spades on amp and speakers. Seem to have a hard time keeping them tight and the other day they touched each other on one speaker and result was a blown tube(could have been worse!). So I'm going back to nanners and to be on the safe side maybe they should be insulated? Locking screws for wire connection preferable to solder.
Yep, my name really is Bob.
    mhardy6647 Posts: 35,376
    muncybob wrote: »
    ... the other day they touched each other on one speaker and result was a blown tube(could have been worse!)...
    That is very odd -- vacuum tube audio amplifiers don't usually mind short circuits.
  • muncybob
    muncybob Posts: 3,280
    The amp's(ss) protection circuit kicked in. The tube was in the pre....not sure if that's unusual or not.
    edited July 2019
    That seems even odder -- although I do have a terrible head cold and I am not thinking clearly.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I like the AQ SureGrip bananas.
    Nice tight fits.... If it ain't tight it ain't worth a ____
    Garage | Polk Monitor 5B's
  • dragon1952
    dragon1952 Posts: 4,939
  • delkal
    delkal Posts: 764
    When I tighten spades to a post I don't just screw down the post. I start that way but when it seems tight I then wiggle the spade (there is always some play), back it off a bit and tighten the last time by moving the spade AND the post screw together. You can get it a lot tighter. Just be careful......don't overtighten it and break something.
    Or how about electrical tape?
  • muncybob
    As is often said, pics or it didn;t happen,
    Oh, I believe it happened -- I just cannot fathom why.
  • dragon1952
    Better than a blown speaker.
