Polk Audio Monitor 7 Series 2
Can anyone tell me what I need to buy for capacitors to upgrade my speaker? I can see numbers on a couple of them but one I cannot see and they are all glued down right now.
    F1nut Posts: 52,008
    The schematic is listed if you look.
  • ace218
    ace218 Posts: 4
    Thanks. I was hoping someone had a list of what is needed. I am not that familiar with schematics and the capicitors that are replacements for the originals.
    F1nut Posts: 52,008
    edited June 2019
    The values are listed on the schematic. If you can read them off the board components you can read them off the schematic.
  • verb
    verb Posts: 10,176
    Welcome Ace! Here's a link to the schematics page. I'm sure others will chime in, as it's always good to see someone like yourself ready to take on an upgrade! :smile:
    https://forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-amp-more-all-models-except-sda#latest
  • verb
    verb Posts: 10,176
    And, if you do a search here for monitor 7, you'll find many folks have taken the journey! Good luck and keep us posted! :smile:
    F1nut Posts: 52,008
    He has the 7 series 2 not the original 7's.
  • ace218
    ace218 Posts: 4
    Would this be the right one? I have the SL2500 tweeters, not sure on the driver I would have to check
    pitdogg2 Posts: 27,333
    I do believe so.
  • ace218
    ace218 Posts: 4
    Thanks for all the help. I really appreciate. These speakers sound pretty darn good but I am guessing a capacitor upgrade is going to help some.
  • pkquat
    pkquat Posts: 748
    Another option is to replace the SL2500 tweeter with the RD0-198 available directly from Polk for ~$50 each. Call customer service and tell them you are a polk forum member and get free shipping. IMO the SL2500's sound soft and dull to me. The RD0-198 is much more crisp and detailed without being fatiguing.
  • FestYboy
    FestYboy Posts: 3,861
    Correct me if I'm wrong, but the sl2500 is NOT the TL tweeter and would be replaced with the rd0-194.
  • Jimbo18
    Jimbo18 Posts: 2,351
    FestYboy wrote: »
    The SL2500 and the SL3000 are both replaced by the RD-0198 from what I have read on this site.
    F1nut Posts: 52,008
    Jimbo18 wrote: »
    FestYboy wrote: »
    Correct
  • FestYboy
    Ok, but that's rather confusing to read TL (3k) and 198 in the same breath, but nary the 2500...
    Consider me corrected
