Qobuz sublime +
afterburntafterburnt Posts: 5,806
Anyone subscribe to this? I have bought my last rekid and I'm thinking about going this route
  • mark090852mark090852 Posts: 946
    edited June 19
    I subscribe to the Qobuz Studio Hi-Res plan. It's the same as the Sublime + except it doesn't have the discounted hi-res download feature. I stream only, and have no need to pay for downloads, discounted or not.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • erniejadeerniejade Posts: 5,078
    Hi rez qobuz here as well.
    Den: Lumin D1,Wireworld Silver Eclipse, KEF LS50 Wireless, Velodyne SPL1200, Technics 1200, Denon DL160, Jolida D9,
    Living Room:,T+A PA 1530R, Tyler Highland H2, Aries Mini, High Fidelity Reveal RCA, Grant Fidelity Tube Dac 11, W4S recovery, Wireworld Platinum Starlight, PS Audio Direct Stream JR.
    Have but haven't used in a while: LH Labs VI Dac, Cayin SCD50T
  • DaveHoDaveHo Posts: 2,458
    edited June 24
    What interface do you guys use? I've tried the web app, 32, & 64 bit windows desktop apps. None work correctly. 64-bit flat out won't play anything, regardless of the selected resolution. 32-bit will play. Web app plays everything @ 44.1 regardless of the advertised res. Search works on none. This is a studio subscription on a win10 machine, which is the only device I can use to stream to my work headphone rig.
    Looks like I'll be sticking with Tidal if I can't find a solution before the free trial period ends.
  • vcwatkinsvcwatkins Posts: 1,921
    "Studio" subscription here. Would not break even on download discounts. I use Roon, Sonos (CD quality), and Qobuz iphone (usually CD quality).
    @DaveHo, I would urge you to try Roon if you haven't already. It's made a huge impact on my enjoyment of music.
    Den: Rega RP6 * AT33PTGII * Budgie SUT * Jolida jd9 * Roon (Sonic Transporter) * PS Audio DirectStream Jr. * Joule-Electra LA-100 mkIII * Sunfire Signature II * PSAudio PP3 * MIT S3 * Polk SRS 1.2
    Study: Roon * Sonore UltraRendu (LPS-1, WW Plat7, Iso Regen, Lush) * ProJect Pre Box S2 * Pass ACA * PSA Dectet * DH Labs Q10 * Brines Folded ML-TQWT RS 40-1354
    Studio: SBTouch * Marantz 2270 * Polk CRS+(4.1tl)
    Beach: Music Hall MMF5.1se * Speed Box II * DL103r * Lounge Copla/LCRIII * Sonore microRendu * Schiit Yggdrasil * Belles 20a Pre * Pass Aleph 30 / First Watt F5 Clone * PSA Dectet * MIT S3 * Polk SRS 2.3tl
    Beach Den: Dayens Menuetto * Fostex BK-12m Folded Horn / KEF LS50 / Dynaudio Audience 50 / Revel M22
    Beach Study: LG v30 phone * Schiit Aegir * Zu Omen Dirty W/end
  • rooftop59rooftop59 Posts: 5,960
    vcwatkins wrote: »
    The problem for me (and I suspect Dave) is that I usually work at the office on a different computer than what serves up roon at home, and you can't just switch back and forth. I would have to pay for a second license to use it at work, which ain't gonna happen on my salary lol...
    These kinds of things are one of the main reasons I am happily sticking with TiDAL for now...
    HT Rig:
    Denon AVR-X4200w; Peachtree Audio NovaPre; B&K TX4430; Bryson BPD-1; Mains: Dynaudio Excite x18; Center - Polk cs400i; Heights, Center Surround - Klipsch KHC - 6 In-Ceiling; Surrounds - Monoprice in-ceiling; Sub - HSU VTF-2 MK5; LG UP870 4K BDP; NVidia ShieldTV
    Master Bedroom
    Cambridge Azur 551r; Definitive Technology SM45, NHT Super One CI surrounds, Martin Logan Dynamo (original), Squeezebox Touch
    DaveHo wrote: »
    My Aries mini lightning software and my Lumin D1, using the Lumin software. When I am at work, I use the Qobuz desktop app and the tidal desktop apps. I have listened to 96k using the app but, you have to select your dac or sound card. Next to the volume bar, there is a little plug looking thing. For me I select the Light Harmonic ASIO and it goes to my geek out 1000.
    Yep, Roon really needs to come up with mobile solution. If I had to pick either Qobuz or Tidal based on content, I'd stay with Tidal. I've been using both since Qobuz became available here and have downloaded only one album. Here are my experiences with Qobuz interfaces:
    My 64bit Qobuz PC app works fine. Will play hi-rez through my PC rig where the app is running or Chromecast to Google endpoints (Polk Mini & Google puck thingie worked). Search is working correctly for me. At least Artist search. I may not have tested other searches.
    Web player seems to work the same as above except it does not show a couple local devices that the standalone does. Search working here for me too.
    Qobuz iphone app adds Airplay availability, showing me a Marantz AVR and my iPhone as endpoints. Haven't tried sending to Roku or FireTV with Airplay enabled. Hi-rez play through the Marantz and iPhone works well (at least it indicates 24/96 or 24/192 is playing). The Marantz AVR HT is not the most resolving rig (Polk LSi7), so I cannot be certain; but it sounds very good for this rig. Search working here.
Howdy, Stranger!
