Qobuz sublime +
Anyone subscribe to this? I have bought my last rekid and I'm thinking about going this route
  • mark090852
    mark090852 Posts: 999
    edited June 2019
    I subscribe to the Qobuz Studio Hi-Res plan. It's the same as the Sublime + except it doesn't have the discounted hi-res download feature. I stream only, and have no need to pay for downloads, discounted or not.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • erniejade
    erniejade Posts: 6,321
    Hi rez qobuz here as well.
  • DaveHo
    DaveHo Posts: 3,583
    edited June 2019
    What interface do you guys use? I've tried the web app, 32, & 64 bit windows desktop apps. None work correctly. 64-bit flat out won't play anything, regardless of the selected resolution. 32-bit will play. Web app plays everything @ 44.1 regardless of the advertised res. Search works on none. This is a studio subscription on a win10 machine, which is the only device I can use to stream to my work headphone rig.
    Looks like I'll be sticking with Tidal if I can't find a solution before the free trial period ends.
  • vcwatkins
    vcwatkins Posts: 1,992
    "Studio" subscription here. Would not break even on download discounts. I use Roon, Sonos (CD quality), and Qobuz iphone (usually CD quality).
    @DaveHo, I would urge you to try Roon if you haven't already. It's made a huge impact on my enjoyment of music.
  • rooftop59
    rooftop59 Posts: 8,120
    vcwatkins wrote: »
    The problem for me (and I suspect Dave) is that I usually work at the office on a different computer than what serves up roon at home, and you can't just switch back and forth. I would have to pay for a second license to use it at work, which ain't gonna happen on my salary lol...
    These kinds of things are one of the main reasons I am happily sticking with TiDAL for now...
    Game Room 5.1.4:
    Bedroom 2.1
  • erniejade
    DaveHo wrote: »
    My Aries mini lightning software and my Lumin D1, using the Lumin software. When I am at work, I use the Qobuz desktop app and the tidal desktop apps. I have listened to 96k using the app but, you have to select your dac or sound card. Next to the volume bar, there is a little plug looking thing. For me I select the Light Harmonic ASIO and it goes to my geek out 1000.
  • vcwatkins
    Yep, Roon really needs to come up with mobile solution. If I had to pick either Qobuz or Tidal based on content, I'd stay with Tidal. I've been using both since Qobuz became available here and have downloaded only one album. Here are my experiences with Qobuz interfaces:
    My 64bit Qobuz PC app works fine. Will play hi-rez through my PC rig where the app is running or Chromecast to Google endpoints (Polk Mini & Google puck thingie worked). Search is working correctly for me. At least Artist search. I may not have tested other searches.
    Web player seems to work the same as above except it does not show a couple local devices that the standalone does. Search working here for me too.
    Qobuz iphone app adds Airplay availability, showing me a Marantz AVR and my iPhone as endpoints. Haven't tried sending to Roku or FireTV with Airplay enabled. Hi-rez play through the Marantz and iPhone works well (at least it indicates 24/96 or 24/192 is playing). The Marantz AVR HT is not the most resolving rig (Polk LSi7), so I cannot be certain; but it sounds very good for this rig. Search working here.
