RTI A5 replace 6-1/2 "composite woofer
Hi guys,
I have this pair of RTI A5s purchased around 10 years go. The four 6-1/2 Dynamic Balance polymer composite woofers in both the speakers have started cracking. Where can I purchase a replacement for the same? I think I should be able to fix the new ones myself.
Thanks in advance.
Onkyo 727| Polk RTi A5 biamped| Polk RTi4s surrounds| Polk CSi3 center| subwoofer PSW404 :)
    pitdogg2 Posts: 27,069
    Cracking? How about pictures
  • rooftop59
    rooftop59 Posts: 8,121
    Yea that sounds strange. Polk is your main source, but there may be other suppliers that have stock from Polk...
    Game Room 5.1.4:
    Bedroom 2.1
  • johy
    johy Posts: 17
    edited June 2019
    Thanks, The cones are actually cracking up. I can see around 4 cracks in each of the cones. Will post pics later.
    Sorry I mean to type cones..it is a ruptured cone problem, not the diaphragm. How can I repair them ? Parts ?
    Post edited by johy on
    tonyb Posts: 33,072
    Cracking ? don't think I ever seen that happen before. Can you post a pic of the worst one ?
    F1nut Posts: 51,794
    Says severely overdriven to me.
    tonyb Posts: 33,072
    That's what I was thinking, but even then....don't think I ever seen a cone crack as described. All of them yet ? I've seen 50 year old speakers with no cracked woofers, ripped maybe because they were paper back then. Todays more stiffer drivers should not crack I would think. Plus to over drive a speaker that badly, you'd think a crossover might go up in smoke first.
    Pictures tell a thousand words though.
    some of the new drivers actually get brittle with age. maybe the "aerated" sandwich is separating. IF those drivers have that material.
    tonyb Posts: 33,072
    Possible Ivan, but RTIA5's that are only 10 years old ?
    VR3 Posts: 29,442
    edited June 2019
    The cones are a simple polymer, should last.... "a life time"
  • johy
    johy Posts: 17
    Here is the pic of the worst one. I have never over driven them. My earlier AV receiver , an Onkyo 727 , did burn up, and I wonder if it caused this. I am back to my earlier Denon now, which I have used for a long time.ovw4s0ifxxoe.jpg
    VR3 Posts: 29,442
    There is something off about the color of the screws, have you had them in sunlight or near a window
    Looks like just the dust cap is damaged which wouldn't be hard to fix
    F1nut Posts: 51,794
    That's the dust cover and looks to me like the result of overheated voice coils.
  • johy
    johy Posts: 17
    edited June 2019
    Thanks guys. Sorry I am not so tech savvy with the names. It is the dust cover then. Can I just buy the dust cover from somewhere, open the speakers and reattach them? The speakers are in a room upstairs. It can get very hot there. There are no windows..just a big door. Air conditioned dedicated home theatre.
    Where can I buy them? And what size,.they seem like 2" when I measured them across.
    F1nut Posts: 51,794
    Google replacement speaker dust caps or you can have them replaced here, https://www.midwestspeakerrepair.com/speaker-repair-prices/
    VR3 Posts: 29,442
    How hot is very hot? Really indoor speakers shouldnt experience drastic temperature swings. I have seen cabinets split apart, veneer peel, driver damages, etc...
    Are the grills kept off and they could get a few hours of direct sunlight?
  • johy
    johy Posts: 17
    When the door is closed, in peak summer , it would be 100-110 F. Grills are removed yes, and I could sun the grills
    F1nut Posts: 51,794
    Way too hot.
  • rooftop59
    Million dollar question, do they sound any different? If not, just leave em....
    Game Room 5.1.4:
    Bedroom 2.1
  • johy
    johy Posts: 17
    They sound the same. Think I might as well leave them.
    johy wrote: »
    you misunderstood my question as I phrased it poorly. I was asking if the drivers were also getting direct sunlight with the grill off. Direct sunlight will also heat up the drivers much more than the room temp. therefore direct UV radiation can cause the cracks.
  • tonyp063
    tonyp063 Posts: 1,134
    He did say that the room had no windows, just a door & was an A/C cooled dedicated HT room.
    Could it be severe lack of humidity? Or drastic temp swings?
    F1nut Posts: 51,794
    Needs to leave the A/C on.
    nooshinjohn Posts: 25,932
    johy wrote: »
    Where do you live?
    tonyp063 wrote: »
    ok I missed that my bad....
