RTI A5 replace 6-1/2 "composite woofer
Hi guys,
I have this pair of RTI A5s purchased around 10 years go. The four 6-1/2 Dynamic Balance polymer composite woofers in both the speakers have started cracking. Where can I purchase a replacement for the same? I think I should be able to fix the new ones myself.
Thanks in advance.
Onkyo 727| Polk RTi A5 biamped| Polk RTi4s surrounds| Polk CSi3 center| subwoofer PSW404 :)
  • Unknown
  • rooftop59
    rooftop59 Posts: 8,120
    Yea that sounds strange. Polk is your main source, but there may be other suppliers that have stock from Polk...
    Game Room 5.1.4:
    Bedroom 2.1
  • johy
    johy Posts: 17
    edited June 2019
    Thanks, The cones are actually cracking up. I can see around 4 cracks in each of the cones. Will post pics later.
    Sorry I mean to type cones..it is a ruptured cone problem, not the diaphragm. How can I repair them ? Parts ?
    Cracking ? don't think I ever seen that happen before. Can you post a pic of the worst one ?
    F1nut Posts: 52,406
    Says severely overdriven to me.
    That's what I was thinking, but even then....don't think I ever seen a cone crack as described. All of them yet ? I've seen 50 year old speakers with no cracked woofers, ripped maybe because they were paper back then. Todays more stiffer drivers should not crack I would think. Plus to over drive a speaker that badly, you'd think a crossover might go up in smoke first.
    Pictures tell a thousand words though.
  • Unknown
    Possible Ivan, but RTIA5's that are only 10 years old ?
    VR3 Posts: 29,752
    edited June 2019
    The cones are a simple polymer, should last.... "a life time"
  • johy
    johy Posts: 17
    Here is the pic of the worst one. I have never over driven them. My earlier AV receiver , an Onkyo 727 , did burn up, and I wonder if it caused this. I am back to my earlier Denon now, which I have used for a long time.ovw4s0ifxxoe.jpg
    VR3 Posts: 29,752
    There is something off about the color of the screws, have you had them in sunlight or near a window
    Looks like just the dust cap is damaged which wouldn't be hard to fix
    F1nut Posts: 52,406
    That's the dust cover and looks to me like the result of overheated voice coils.
  • johy
    johy Posts: 17
    edited June 2019
    Thanks guys. Sorry I am not so tech savvy with the names. It is the dust cover then. Can I just buy the dust cover from somewhere, open the speakers and reattach them? The speakers are in a room upstairs. It can get very hot there. There are no windows..just a big door. Air conditioned dedicated home theatre.
    Where can I buy them? And what size,.they seem like 2" when I measured them across.
    F1nut Posts: 52,406
    Google replacement speaker dust caps or you can have them replaced here, https://www.midwestspeakerrepair.com/speaker-repair-prices/
    VR3 Posts: 29,752
    How hot is very hot? Really indoor speakers shouldnt experience drastic temperature swings. I have seen cabinets split apart, veneer peel, driver damages, etc...
  • Unknown
  • johy
    johy Posts: 17
    When the door is closed, in peak summer , it would be 100-110 F. Grills are removed yes, and I could sun the grills
    F1nut Posts: 52,406
    Way too hot.
  • rooftop59
    Million dollar question, do they sound any different? If not, just leave em....
    Game Room 5.1.4:
    Bedroom 2.1
  • johy
    johy Posts: 17
    They sound the same. Think I might as well leave them.
  • Unknown
  • tonyp063
    tonyp063 Posts: 1,157
    He did say that the room had no windows, just a door & was an A/C cooled dedicated HT room.
    Could it be severe lack of humidity? Or drastic temp swings?
    F1nut Posts: 52,406
    Needs to leave the A/C on.
  • Unknown
  • Unknown
