SDA-CRS as center channel for 1A’s?! Or klipsch RC-64
Sorry but I know this has to have been asked somewhere but I cannot seem to find exactly what I’m looking for. I have a Pair of SDA-CRS that I think would possibly work for tweeter matching. I’m either looking at doing this or looking into buying either the SVS prime center, SVS ultra center, or Klipsch RC-64. Whats the consensus on center channels for SDAs?
  • pitdogg2pitdogg2 Posts: 13,483
    SDA CRS would match better
  • westmassguywestmassguy Posts: 6,346
    A single CRS+, with a Monitor 10 crossover makes an exceptional center.
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Exclusive Distributor of Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • Joshwest90Joshwest90 Posts: 69
    What does the monitor 10 crossover change that the crs crossover doesn’t have?
    Joshwest90 wrote: »
    No SDA woofer.
    Joshwest90 wrote: »
    No SDA woofer.
    Could you not unplug the dimensional woofer on the CRS
    The Monitor 10 crossover is designed for a single tweeter, dual woofer configuration.
    The CRS crossover is not.
    Den:
    edited June 11
    Joshwest90 wrote: »
    Joshwest90 wrote: »
    No SDA woofer.
    Will sure but why? The crs+ should have bass down below 150hz. i believe unlike the earliest model that didn't play at all unless the cable was used. I'd give it a try and see how you like it first. Dave knows his stuff that i trust.
    These CRS were made in 84 they aren’t the + correct
    Blade blade interconnect and two tweeters then no.
    Yes blade/blade and two tweeters. So do I look for a different center or try it
    Disable one of the tweeters, and install the Monitor 10 crossover, done. Use the tweeter that's mostly in the center.
    Den:
    Would using both as a center cause an issue?
  • FestYboyFestYboy Posts: 3,528
    Yes, you will get lobing, and a comb filtering. Ideally, one full range driver per channel will deliver the cleanest sound, so the closer the drivers are to each other, the closer it will act as a single driver.
    Joshwest90 wrote: »
    Both tweeters or both speakers?
    Joshwest90 wrote: »
    Both speakers
    Joshwest90 wrote: »
    Go with a single CRS.
    Den:
  • CH46ECH46E Posts: 1,023
    edited June 15
    Joshwest90 wrote: »
    Joshwest90 wrote: »
    No SDA woofer.
    You wont like it that way. The one woofer will bottom out pretty easy since it's now having to try and drive the PR and a second woofer.
    I wired my CRS, SDA woofer with the other woofer so it was more like a 2 way 3 driver speaker. I dont remember (parallel or series) but I think it came out in the 5 to 6 ohm range. Made for a pretty capable center with plenty of bass. Dont forget to allow some room for the PR to breathe on the back.
Howdy, Stranger!
