Need some prayers my way
nooshinjohn
nooshinjohn Posts: 25,954
edited June 2019 in The Clubhouse
I am dealing with a severe case of Diverticulitis, and am experiencing all the symptoms. Severe lower stomach pain, constipation hot and cold flashes... the works. I will be going to go to my urgent care in the morning, and I fear the worst, which will be going through the same type of surgery/recovery as Motörhead... I don’t have more info than this right now, but it has been debilitating pain now for 36 hours...
Thanks guys, we all have seen the power of prayer this week, maybe there is just a bit more out there...
«13
  • BlueFox
    BlueFox Posts: 15,250
    Good luck. Hope it is a simple fix.
  • gmcman
    gmcman Posts: 1,857
    Oh man....hopefullly you can get this taken care of quickly....prayers sent.
    Clipdat Posts: 13,098
    Yikes, that sounds awful. Hope you can get some relief soon. Let us know what they say at the doctor tomorrow.
  • kharp1
    kharp1 Posts: 3,453
    Sorry to hear this, have a buddy that's been dealing with this recently. Know it's not easy.
  • indyhawg
    indyhawg Posts: 1,673
    Prayers sent, John. Hope you get a good medical report today.
  • joecoulson
    joecoulson Posts: 4,943
    Prayers do work, I will ask God for his grace. Take care John.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Hope you get better soon John!
  • shawn474
    shawn474 Posts: 3,052
    Absolutely!!!! Sent in abundance. Hope you can get through this rough patch and be well soon John. Take care
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
    mhardy6647 Posts: 35,147
    Ouch (literally and figuratively). You've got it, sir.
    Please do keep us posted as (and if) you're able to.
    I think that there are a spectrum of possible outcomes, so it won't necessarily be the worst case in terms of required medical intervention!
  • oldrocker
    oldrocker Posts: 2,590
    Consider it done and any others that are having trying times.
  • Dabutcher
    Dabutcher Posts: 2,606
    Good luck . Sounds terrible. Prayers and positive vibes your way. Peace. D
  • westmassguy
    westmassguy Posts: 6,850
    Praying for you.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • motorstereo
    motorstereo Posts: 2,358
    Thoughts and prayers sent your way John.
  • pglbook
    pglbook Posts: 2,262
    John, my wife and I have you in our thoughts and prayers. Hope all turns out well.
  • Milito
    Milito Posts: 2,003
    edited June 2019
    A friend of mine had it and they fixed him and he has been fine for 3-4 years. Prayers and good luck John!
  • miner
    miner Posts: 1,305
    John, may you recover quickly my friend.
  • polrbehr
    polrbehr Posts: 2,846
    Done. Hope everything goes smoothly for you.
  • rooftop59
    rooftop59 Posts: 8,120
    Grace and peace John.
    Game Room 5.1.4:
    Bedroom 2.1
  • halo
    halo Posts: 5,616
    Speedy recovery John :)
    They put me on antibiotics and stool softeners to clear the obstruction, then next week I go see a gastroenterologist to see what is happening in there. More to come I’m sure...
  • jflail2
    jflail2 Posts: 2,868
    Good luck John, that sounds pretty miserable. Hope they get you to feeling better soon!
    Tony M Posts: 11,673
    edited June 2019
    Wow...I got really scared there for a few minutes!
    I was hoping it was just a blockage of some kind and could be alleviated.
    I had a masseuse/acupuncturist ask me what was the heck was in my gut. I said I didn't know but my right side definitely was bothering me. It was like a baseball bat shape on my right side. Hard too. I got acupunctured on that right side of my gut that session per his request. After I got home...well let me simply say the blockage moved. :D
    I pray the Gastro Doc. gives you good news. ;)
    I'm sending some prayers your way in the coming days!
    EndersShadow Posts: 17,713
    Sorry to hear John, hopefully it passes easily....
  • Mikey081057
    Mikey081057 Posts: 7,127
    Get well soon John... Positive thoughts and prayer will get you through this.
    Garage | Polk Monitor 5B's
  • xsmi
    xsmi Posts: 1,804
    I hope you feel better soon. John! Still praying, my friend.
    2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
  • Joey_V
    Joey_V Posts: 8,603
    If you’re on cipro and flagyl, low residue diet, you should be ok.
    Good luck John
  • aprazer402
    aprazer402 Posts: 3,400
    edited June 2019
    Glad to hear you're being treated. I'll say one for you. You'll be fine Marine! :)
  • WagnerRC
    WagnerRC Posts: 2,209
    good thoughts and prayers headed your way. Get well soon.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    Prayers conveyed. I hope you feel better.
