LSI25 sound difference
Hello,
I'm hoping someone here might have some good advice for me because i'm feeling pretty lost at this point. I have recently purchased a pair of LSI25s used, for what I thought was a good deal (at the time). However, after getting them home and listening to them using multiple amplifiers it is clear that one speaker is louder than the other. I switched the drivers from one speaker to the other and nothing changed, the left channel stayed louder. However, when I switched the crossover, the right channel became the louder one. Thinking I had discovered the problem I took the crossover to a local electronics repair shop who tested the components and found them to be perfectly in spec, leaving me pretty baffled. He also was unable to think of a reason for the difference and agreed something was pretty strange. Now ive also noticed a couple other differences between the two. When looking at the driver dates it is clear that one speaker was made probably 3-4 years before the first based on dates on drivers and internal components, and the subwoofer drivers have a different appearance and one is deeper than the other by about 1/2 an inch even though they have the same part #. My main question is would it be possible for the difference in sound to be due to a late model vs early model having a slightly different sound? or should I stay with my feeling that the crossover is the problem (not that I can find one anyway). I love the sound of the louder speaker and would appreciate any help to restore these speakers to the way they should sound if possible. Thanks.
    F1nut Posts: 52,009
    The schematic is posted in this thread, https://forum.polkaudio.com/discussion/38755/polk-audio-speaker-wiring-schematics-amp-more-all-models-except-sda
    You're going to have to compare everything between the two speakers including the subwoofer amps. I'm unaware of any changes during production, but anything is possible.
  • skrol
    skrol Posts: 3,464
    The speaker drivers should have stickers with the model numbers. Are they the same between the two speakers?
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Same model number non consecutive serials. I'm getting a dead link for the schematic.
    F1nut Posts: 52,009
    edited June 2019
    I see what you mean, oh well.
  • Anyone have an idea what i should be checking/ have the XO schematic? Any help would be very appreciated.
    F1nut Posts: 52,009
    edited June 2019
    You'd have to pull everything to compare components, but as you already noted they are years apart and have different subwoofers, so it's obvious they are a mismatched pair. As parts such as the subwoofer are not available it may simply be time to punt.
  • polrbehr
    polrbehr Posts: 2,852
    edited June 2019
    Didn't I read somewhere that there was a drop-in replacement subwoofer for these? I could have sworn some folks swapped in different drivers, maybe like an 8" car audio sub? If it won't cost too much to try, it may be worth it.
    *eh, maybe not, I see the OP swapped Xovers and the problem was still there.
    txcoastal1 Posts: 13,519
    polrbehr wrote: »
    That was the LSi15 not the 25's
