Parasound HCA-1000A
rooftop59
rooftop59 Posts: 8,121
edited May 2019 in For Sale (FS) Classifieds
Great amp for sale. I’ve had several over the years and keep coming back to them whenever I need solid, inexpensive power. This one is in about the best shape of the used ones I’ve owned, but one rack ear did get bent in shipping and the previous owner bent it back. Other than that, there are a few small scratches, but no other major imperfections. Face is pretty clean.
$200 plus actual shipping for polkies with 100 posts. Paypal preferred. Please cover any applicable fees. Thanks!
Game Room 5.1.4:
Bedroom 2.1
Post edited by rooftop59 on
  • codycatalist
    codycatalist Posts: 2,662
    Tempting. Good deal, I usually see these for around $250-300
  • rooftop59
    Yep, this is one the the classic amps that has really held its value over the years. You will not lose any money if you decide to resell any time in the foreseeable future...
    Game Room 5.1.4:
    Bedroom 2.1
  • gyosa
    gyosa Posts: 770
    Any idea on the age of it ?
    Still looking for an amp ....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
  • gyosa
    gyosa Posts: 770
    I can repost this 22 more times to get to 100 ...😊😊
  • rooftop59
    No sorry, but I imagine one could call parasound with the serial number.
    Fwiw most of these were made in the early 2000s I think...
    Game Room 5.1.4:
    Bedroom 2.1
  • gyosa
    gyosa Posts: 770
    Wondering how long these go before they need any servicing ?
    Bk
  • muncybob
    muncybob Posts: 3,239
    I have the HCA-1000(not the A version) so slightly older and not a thing wrong with it. Good amp for the $$.
    Yep, my name really is Bob.
  • kevhed72
    kevhed72 Posts: 5,142
    Someone needs to buy this....had one for awhile and great bang for your buck!
  • rooftop59
    edited May 2019
    The 1000A is 45 AMPS peak current, 125 watts a channel, THX certified, mono option for a sub. Also has remote trigger. The 1000 had 25 AMPS peak, 100 WPC, no remote option FWIW...
    1000A:
    Continuous Power Output - Stereo
    125 watts RMS x 2, 20 Hz-20 kHz, 8 Ω, both channels driven
    200 watts RMS x 2, 20 Hz-20 kHz, 4 Ω, both channels driven
    Continuous Power Output - Mono
    400 watts RMS, 20 Hz-20 kHz, 8 Ω
    Current Capacity
    45 amps peak per channel
    Game Room 5.1.4:
    Bedroom 2.1
  • gyosa
    gyosa Posts: 770
    ROOFTOP ,
    I’m very interested , if you’ll give me a pass on the 100 posts ....
    Whaddya think shipping is to 75214 , Dallas TEXAS ( notice all caps ? Everything bigger in TEXAS )....
    Bk
  • gyosa
    gyosa Posts: 770
    More importantly, what are the collective thoughts about how this would pair with my new Salks ?
    The Parasound A23 I was interested in is unavailable... he decided to keep it ....
    I don’t have a problem going with a new amp or used ....
    Appreciate any input ....
    Bk
  • gyosa
    gyosa Posts: 770
  • DaveHo
    DaveHo Posts: 3,583
    That cabinet is cool. But it reminds me of a Minecraft block. :)
  • DaveHo
    DaveHo Posts: 3,583
    But on a serious note. The 1000a will power the Salks beautifully.
  • gyosa
    gyosa Posts: 770
    Yeah ,
    Wife fell in love w it .....
    Teak ....
    I’ll build a boat ‘outta it when we retire .... 😊
    Bk
  • Inspector 24
    Inspector 24 Posts: 1,308
    Tempting indeed, just to have just in case
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • rooftop59
    gyosa wrote: »
    ROOFTOP ,
    Bk
    Pm sent.
    Game Room 5.1.4:
    Bedroom 2.1
  • gyosa
    gyosa Posts: 770
  • gyosa
    gyosa Posts: 770
    PM BACK AT ‘ya ...
  • rooftop59
    edited May 2019
    In talks with @gyosa...
    Game Room 5.1.4:
    Bedroom 2.1
  • codycatalist
    W00t get dat amp!
    tonyb Posts: 33,072
    Those looking to add an amp on the cheap, a good amp, would be foolish to pass on this.
  • scubalab
    scubalab Posts: 3,105
    edited May 2019
    I had one of these. Probably the piece of gear I regret selling the most!
    Great seller too!
  • muncybob
    rooftop59 wrote: »
    1000A:
    Current Capacity
    I though the only difference between the 2 was the "A" had power on auto trigger?
  • rooftop59
    muncybob wrote: »
    rooftop59 wrote: »
    1000A:
    Current Capacity
    Nope! Changes are as listed. John curl took the opportunity to make some improvements...
    Game Room 5.1.4:
    Bedroom 2.1
  • aiconn
    aiconn Posts: 277
    Pm sent
    PS Audio Stellar Gain Cell DAC/Preamp
    Denon DVD 2910
    Quad 12L Active Monitors
    Marin Logan Dynamo 700W
  • skrol
    skrol Posts: 3,450
    gyosa wrote: »
    Bk
    I have one that I bought from a fellow Polk Audio member. One channel was out but it turned out to be a broken solder joint, easy fix. I decided to refresh the caps but there wasn't much need. All the caps I pulled out were still in good spec. An older Parasound amp that I had (HCA-800ii) had many bad caps but that was before John Curl stepped in. The HCA-1000A has much better quality caps. I was able to upgrade the power supply caps to higher capacity and higher voltage rating. With advice from Mr. Curl himself, I was able to set the bias quite a bit higher than the factory setting. It is a really nice amp.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • rooftop59
    Still available!
    @aiconn you're up!
    Game Room 5.1.4:
    Bedroom 2.1
  • Inspector 24
    Damnit someone buy this so I don't...My Parasound FanBoi keeps poking me...
    Up
    Down
  • rooftop59
    SOLD!
    Game Room 5.1.4:
    Bedroom 2.1
